Stair Tread And Riser Assembly - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 01:09 PM   #1
Rewards Points: 1,062
Stair tread and riser assembly
When assembling stair treads and risers, is it better to have the tread tucked under the riser or have the riser tucked in between the tread and the stringer riser backing? I am inclined to think the former because that way the tread gets more framing support but the way my current stairs are assembled is the latter, hence my uncertainty. See picture.
Old 06-13-2013, 02:03 PM   #2
kwikfishron's Avatar
Rewards Points: 576
You install the risers first and then the treads.
kwikfishron is online now   Reply With Quote
The Following 3 Users Say Thank You to kwikfishron For This Useful Post:
amakarevic (06-13-2013), BigJim (06-13-2013), CENTERLINE MV (06-26-2013)
Old 06-13-2013, 02:07 PM   #3
That's the way the old ones are. Thanks
Old 06-13-2013, 02:19 PM   #4
Old School
Willie T's Avatar
And you also go behind the risers, and give extra attachment and support to the treads in the form of glue and screws through the risers into the back edge of the tread.
Treads are only providing support of a measly 1-1/2", or so... however thick they are. This is not much.
The risers, on the other hand are installed like floor joists are installed, on edge, giving you about 7" of very solid support all across under the front edges of the treads. It makes equally good sense to support the back edges of these relatively thin treads by fastening them into the bottom of the risers.
I even dado the bottom edge of the risers for this express purpose... as shown in these drawings.
Stair tread and riser assembly-stair-const.-1.jpg   Stair tread and riser assembly-stair-const.-2.jpg   Stair tread and riser assembly-stair-const.-3.jpg   Stair tread and riser assembly-stair-const.-4.jpg
Willie T
Old 06-13-2013, 02:27 PM   #5
Rewards Points: 13,694
Look closer, sure looks like his are already datoed with just a slot for the tread to slide into.
Old 06-13-2013, 02:34 PM   #6
Old School
Willie T's Avatar
Yeah, maybe. I can't really tell. If so, then he already knew the answer to his question before posting.
Willie T
Old 06-26-2013, 11:14 AM   #7
Risers first then treads. Dadoed is definitely better but not absolutely necessary. Screws are also best but 2 1/2" ring shank nails work great also and are faster. Just make sure that you apply construction adhesive to all wood to wood surfaces.
1. Back of Tread to Riser (dadoed or not)
2. Top of Riser to bottom of Tread
3. Both tread and riser to the stringers.
This will insure that the treads are secure and that they will not squeak.
titanjt is offline   Reply With Quote
Old 06-26-2013, 12:49 PM   #8
Old School
Willie T's Avatar
T is right. Don't be cheap with the adhesive... load it up.
Willie T
Old 06-26-2013, 06:40 PM   #9
recently retired
Rewards Points: 280
Wait, nobody has an opinion about the dovetailed balusters?
Keith Mathewson is offline   Reply With Quote
Old 06-26-2013, 11:16 PM   #10
Old School
Willie T's Avatar
Well, I guess it's kind of an interesting detail.......
Willie T
Old 06-27-2013, 07:40 PM   #11
recently retired
Rewards Points: 280
It is interesting, but only because almost nobody does it this way anymore. Balusters which have been dovetailed add a tremendous amount of strength to the handrail.
Old 06-27-2013, 07:57 PM   #12
Rewards Points: 576
That stringer is a beautiful piece of wood.
Old 06-28-2013, 05:26 AM   #13
DIY staff
Rewards Points: 7,174
I place stair masters at the top of the wood working trade----L love the dovetailed balusters.
Old 06-28-2013, 08:07 AM   #14
Old School
Willie T's Avatar
I tried one at the gym, and it really was a good machine.
Willie T
Old 06-30-2013, 06:44 AM   #15
DIY staff
Ho Ho Ho---Willie, To build a properly functioning stair is a challenge---to make that look like a work of art? That makes them a Master and always someone who will have my admiration----
Stair Riser question CharlieR Flooring 1 02-24-2013 01:09 PM
Will these stairs pass IBC code? jonrya91 Building & Construction 21 11-02-2012 08:26 AM
Deck stair tread and riser aesthetics jenmarie Carpentry 4 07-17-2012 04:40 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 05:46 PM
Stair Tread And Riser Installation Speckert General DIY Discussions 3 11-19-2008 02:33 AM
