Stair Stringer Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-10-2014, 03:05 PM   #1
Stair stringer question
Hi.
We're redoing our tread and risers on our interior staircase. I encountered a broken notch on the right side stringer as I pulled up the tread. It's in the middle of a 13 step staircase. Can I just sister up a 1x4 to the broken part and the solid part of the stringer? Could I use a wood glue or epoxy to bind back to the stringer? Do I have to replace the stringer?
Thanks in advance,
Unhandyman
unhandyman1 is offline   Reply With Quote
Old 08-10-2014, 03:22 PM   #2
Framing Contractor
Rewards Points: 120
If just the tip broke off, you should be fine. The grain often breaks there and it wont hurt the structural integrity.
sixeightten is online now   Reply With Quote
Old 08-10-2014, 04:03 PM   #3
Not sure what you mean by the tip but it is a 6 1/4x 5 1/4 triangle. I tried to post a pic but for some reason am not allowed to.
Old 08-10-2014, 04:44 PM   #4
Framing Contractor
Rewards Points: 120
That triangle just broke off right with the grain, they often do even when we build them new. You can probably just glue and screw it back on. Use glue on your treads and risers when you re install and your good to go.
Old 08-11-2014, 09:07 AM   #5
Rewards Points: 736
I'd reinforce the whole stringer with 14x2x4, centering it. Then make a sister stringer that'll overlap 2 steps both ways and glue and screw (pre drill). This'll give you solid backer for the broken triangle. If the piece is against a stud wall, you can install the backer on the wall, but that may interfere with drywall.
Tread should be fixed to the sister stringer.
carpdad is offline   Reply With Quote
Old 08-11-2014, 03:15 PM   #6
Rewards Points: 440
I would give it a shot of pl premium construction adhesive and clamp or screw in place. Once that dries glue the treads down and you will be fine. Ron
ront02769 is offline   Reply With Quote
Replacing stair tread on closed stringer stairs... J187 Carpentry 11 01-16-2017 06:24 PM
Stair Question.. flooringjoe Carpentry 17 03-14-2011 05:27 PM
Stair Tread Replacement Question Mikedks Flooring 6 07-14-2008 04:04 PM
Deck Stair Question Uncle Larry Building & Construction 10 06-19-2008 07:08 PM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
