Stair Stringer Question... - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 10:35 AM   #16
Rewards Points: 6,089
Are you talking about the sides of the stairs on both sides? ...
not the actual stair steps or risers, right?
Two Knots is offline   Reply With Quote
Old 10-09-2013, 10:53 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
I don't think those are housed stringers, if not then what you are calling stringers are skirt boards, not stringers. I noticed that you don't have returns on the treads, the end grain was routed like a return. Also there is no scotia mold under the tread nose against the riser.
If you take those stairs apart you are going to have some fun getting them back together, unless you really know what you are doing. It is almost a given that you will do more damage than you want to and chances are you will wind up with a fresh install.
Most stairs skirt boards are painted and one main reason is 3/4 inch oak doesn't bend in a radius easily at all. If you had an oak skirt included in your original install, believe me you paid dearly for it. If you decide to tackle this and replace the skirts, you will see what I mean.
One more thing that will give you fits is the sheet rock is butted against the skirt instead of under the skirt.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Duckweather (10-11-2013)
Old 10-09-2013, 11:05 AM   #18
oh, Big Jim...skirt boards, that's what they're called.
We dressed up our ordinary stairs with some
thought; without taking them apart.
I'll take pics later to show you...
I think it would give the OP some food for thought.
The Following User Says Thank You to Two Knots For This Useful Post:
BigJim (10-09-2013)
Old 10-09-2013, 12:14 PM   #19
DIYer
Rewards Points: 249
I would like to replace them on both sides, whatever is painted I would like it to be oak.
The outside part of the staircase where the skirt board meets the drywall I have a good idea what to do. I will apply the veneer and then an oak quarter round or moulding to make a nice transition from the oak to the drywall. I am assuming this is how it should be done. Or at least I don't see anything wrong with doing it that way.
VitoB is offline   Reply With Quote
Old 10-09-2013, 12:43 PM   #20
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 742
Originally Posted by VitoB View Post
When you say rebuild the stairs, you mean removing the entire staircase completely?
I see no way to get the wood grain you want except by getting the old stringers out and having a shop make up all new curved hardwood stringers for it. When removing the treads and risers to install the new curved boards , they are going to be damaged.
Paint is your friend.
Unless you can get a mill worker to somehow veneer them or something. I just don't see it happening, sorry.
Maybe someone else will chime in with more ideas.
I could be wrong.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 10-09-2013, 03:29 PM   #21
The more I read this thread the more confused I get.
Here's how we did our stairs...If you're not capable of running all
the moldings, I'm sure you can buy it...
The oak curvey things we cut out on the right
side was also stained, however, after installation I decided
to paint them white. I like it better white.
We ran nice heavy molding up the stringers on both sides,
also built the wall out under the stringer molding in the front
for more defination...
We also ran all the moldings under the stair risers to beef it up.
I have been wanting to do the decorative curvy things again,
same design, only a little thicker.
The bottom riser was white, we bought oak vaneer;
made a series of slices in the back so that we could bend it around
the step.
I think you have nice steps and risers and I hope you can get some
good ideas from my pic's on how to improve your set up...
Old 10-09-2013, 03:30 PM   #22
second pic
Old 10-09-2013, 03:32 PM   #23
three
Old 10-09-2013, 03:35 PM   #24
soory for the duplicate
Old 10-09-2013, 03:37 PM   #25
The inspector...
The bottom step is the curved step that we ran the oak vaneer around.
Old 10-09-2013, 04:27 PM   #26
DIYer
Rewards Points: 249
Really nice job on the stairs!
Running the moldings under the risers adds a nice touch, I think I will do that also. It finishes it off really nicely.
Now it's just a question of figuring out if I need to take everything apart.
Thanks for posting the pics.
Old 10-09-2013, 04:39 PM   #27
Why would you take anything apart?...
A straight line is the shortest distance between two points...or
something like that.
Take a pic of the entire staircase for me, maybe I can better get
an idea as to why you want to go overkill! Maybe I'm missing
something?
Here's a full view...
Old 10-09-2013, 05:20 PM   #28
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
TK, your stairs look great, I have never seen anyone with stair brackets against the inside skirt board, it does look good though.
You can buy flexible stair brackets online to bend with the radius.
Jim
Old 10-09-2013, 05:27 PM   #29
Big Jim, what do you mean by flexable stair brackets?
How are they flexable?
I like what we did, but I think the stair brackets -- both the oak stained ones, and the painted ones, could be a little thicker and maybe have
a little ogee edge?
Old 10-09-2013, 06:12 PM   #30
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
a little ogee edge?
TK, they are actually bendable I'm sure they are the paint grade though.
Jim
Repair Stair Stringer sunshine54 Flooring 2 11-28-2011 12:06 AM
Stair Question.. flooringjoe Carpentry 17 03-14-2011 06:27 PM
Stair Tread Replacement Question Mikedks Flooring 6 07-14-2008 05:04 PM
Deck Stair Question Uncle Larry Building & Construction 10 06-19-2008 08:08 PM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 09:02 AM
