Stair Skirts / Baseboard Shortcut - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 04:03 PM   #1
jeh
jeh's Avatar
Stair skirts / baseboard shortcut
I am remodeling my basement stairs.
I am replacing the treads with oak, and rises with fiberboard (painted white).
When it comes to do the baseboard up the sides, rather than cutting them to fit around every riser/tread, it seems like it would be faster to just use a long stretch of white wood than I can slide between the wall and risers/treads at the same angle as the stairs, with the edges trimmed to the correct angle...
Is there a reason why other people don't do it this way that I'm not seeing?
jeh is offline   Reply With Quote
Old 03-21-2012, 05:12 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
it depends on the stair and how it was built.. the correct way is to install a 2x4 to the inside stringer which will create a space between the stringer for drywall to fit down in behind and the same for a skirt board.. if this carriage isnt done then the stringer is hard to the wall.. which makes it much harder to install a skirtboard even more so if the treads are already on
woodworkbykirk is online now   Reply With Quote
Old 03-21-2012, 05:15 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
The skirt board goes in before the risers and treads. If the stairs are framed correct they will be a space between the wall and stringer for the skirt to slide down into.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
kj6887 (03-21-2012), Willie T (03-21-2012)
Old 03-26-2012, 08:54 AM   #4
Haverhill Trade 1965
Probably most people do not have a space to insert a board. This is a newer method of installing stairs with a spacer between the wall studs and stringers. My guess is that you have a newer house. I install skirt boards this way all the time. It is however, not the "best" way, which is much more complicated. If you start at bottom each one you install may spread the skirt boards so it creates a gap at the end in the one before I would suggest installing a couple of the treads in the middle of the stairs first because the pressure will bow the walls just slightly so the remainder may not.
Duckweather is offline   Reply With Quote
Old 03-26-2012, 03:08 PM   #5
every professional stair installer i know starts at the bottom and works his way up.. if anything the tread and riser get cut slightly smaller than the space then the skirt board gets shims behind it to tighten up the joint
Old 03-29-2012, 06:19 PM   #6
Yeah woodwork, I should have mentioned temporary in the middle to put pressure on the skirts. Then I take them out so I can nail the risers to the back of the treads. Sometimes I wonder if there is a limit on how long a message can be. I hate it when I am still typing but the computer has stopped in the middle of a word
Old 03-29-2012, 11:17 PM   #7
jeh
jeh's Avatar
it turns out that not only do I have a 3/4" space between the stringer and drywall, but also there is a sloped piece of wood running at the bottom of that space....
So I have been able to slide some board in there, and it is already at the perfect angle to the stairs!
The space was previously filled with expanding foam. Not sure why because the old treads were extra wide and covered over it (so they were flush with the walls without baseboard) - its not like rodents could have got in.
Old 03-29-2012, 11:39 PM   #8
jeh
jeh's Avatar
btw my house was built in 1990, so not too new.
It's north of Nashville
Old 03-30-2012, 12:39 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
jeh, that is a 2X4 spacer nailed to the stringer for the very purpose of installing sheet rock and a skirt board, be sure to clean out any trash that might be in there or the skirt won't set down all the way.
Jim
Old 03-30-2012, 08:08 AM   #10
jeh
jeh's Avatar
i ran my compressor blower along there and then my shop-vac!
thanks for the tips y'all
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 03:39 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
