Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-27-2009, 08:26 PM   #1
stair railing
I need help with a couple of things. How do you attach the railing to a half newel, question one. How do I figure out the baluster spacing from the half newel to the newel and are the balusters attached to the railing with a 1" finish nail with glue? Thank you so much for any help.
rocksaranac is offline   Reply With Quote
Old 04-27-2009, 09:52 PM   #2
Old School
Willie T's Avatar
stair railing
I'm kind of partial to dual dowels and glue for the upper connection. And I like rosettes anyway.
Too many variables on your other two questions to give one definitive answer. At least for this guy.
Willie T
Old 04-27-2009, 10:59 PM   #3
stair railing
post a picture Rock
II Weeks is offline   Reply With Quote
Old 04-27-2009, 11:33 PM   #4
stair railing
To figure out the spacing, you just measure the space between the posts and divide by the number of balusters you want to use. They can't be more then 4" apart.
These balusters need to be securely fastened so they do not pop out. How you fasten them depends on the style you pick out and the railing choice.
Ron
Old 04-29-2009, 10:37 PM   #5
Moderator
stair railing
That 4" apart is no place on that baluster to the next one can be 4" or greater. "Handrails on stairs must not allow a 4" sphere to pass through. (toddler's head) Be safe, G
Old 04-29-2009, 10:42 PM   #6
stair railing
Are the railings round wood? Just drill mating holes in the handrail and use glue to secure them. Most books show to do it this way.
beerdog is offline   Reply With Quote
Extending height of deck railing tntworks General Discussion 4 03-11-2013 08:16 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
wobbly stair wood railing DIY_user Remodeling 1 12-18-2006 10:28 AM
