Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-24-2007, 10:09 PM   #1
Stair rail question
Is a 15' run to long for this length of rail. I've got the rail installed but not the
balusters and it seems to have a little side to side movement.
shimmy25 is offline   Reply With Quote
Old 12-24-2007, 10:13 PM   #2
ICF Construction
Stair rail question
FWIW install a bracket from the handrail to the wall just before it stops and becomes a ceiling...this will 'shorten' the run and should stabalize the whole thing, once you add the ballusters that too will increase the strength as well provided you glue them into the treads and fasten to the handrail
Chris
Chris Johnson is offline   Reply With Quote
Old 12-25-2007, 10:38 AM   #3
Stair rail question
Yep.. I agree with Chris, just figure your spacing on the ballusters so the bracket doesnt interfear.
RTRCon is offline   Reply With Quote
Old 12-25-2007, 02:59 PM   #4
Stair rail question
If the top and bottom posts are solid then like mentioned, use a bracket and make sure you glue and fasten the ballisters good.
ponch37300 is offline   Reply With Quote
Old 12-26-2007, 10:00 AM   #5
Stair rail question
I would suggest putting in the balusters first and then install the bracket. Why do a special layout around something that can be put in later.
Ron
Old 12-27-2007, 10:36 AM   #6
Stair rail question
Ron
Ron- Not sure how you layout the the ballusters, but on something like that, I figure the spacing on the treads and plumb up to the rail. Also makes it easier to get a screw gun in to mount the bracket without the ballusters in the way.
Old 12-27-2007, 03:02 PM   #7
Stair rail question
What you need to do is to make sure the rail is set so the bracket reaches both the wall and the rail if you don't want a spacer on the wall. Or worse, the rails too close to the wall.
My suggestion was more sequence then detail on the brackets. But see if this makes sense. You figure out the baluster spacing. In the space you want to install the bracket, you put some blue painters tape. You start to install the balusters. When you get close to the bracket position and confirm your plan is correct, you drill pilot holes where the bracket is going to be mounted(wall and rail). After you use your finish nailer(and glue) to secure the balusters up to the bracket location, you take a screwdriver and install the bracket. Then work your way to the top of the stairs installing the balusters.
Ron
Old 12-28-2007, 10:49 AM   #8
Stair rail question
Yep.. Makes sence to me.. All except the part about the screwdriver? Looks like he might be a little more than 1 1/2" away from the wall, so he might need a spacer there. I cant tell if its a plowed rail for square top or flush on the underside for spindle ballusters. If its plowed then he'll have to mount the bracket to the fillit piece between the ballusters.
Old 12-28-2007, 11:02 PM   #9
Stair rail question
Thanks everyone for your input.
chair rail question? Yeti Carpentry 4 11-11-2007 08:34 PM
Stair question crapenter25 Carpentry 5 09-22-2007 12:07 AM
Safety rail for loft Pam Remodeling 5 02-26-2007 02:55 PM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 09:02 AM
Stair riser protection question JLam Carpentry 3 09-11-2006 05:28 PM
