Stair Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-17-2007, 01:46 PM   #1
Stair question
Hello!
I have to replace a set of cedar stringers comming off of a bay of a pre-existing home. The existing set of steps has 3 risers and 3 treads but the homeowner would like to have 4 of each. They are attached into the back of the ledger board with stair straps onto the back of the stringer. The ledger board has about 5,000 nails in it and would be a disaster to take down. Is there a way to safely attach the new set of stringers to the ledge board without removing the ledger board from the house? Also, the rise will be 7 and 3/16 for each riser, and I'm having trouble trying to find an appropriate run. Would 11 inches be a good run? (approximately the width of 2 2x6's). Any feedback would be appreciated. Thank you!
jazo911@hotmail.com -troy
crapenter25 is offline   Reply With Quote
Old 09-17-2007, 02:05 PM   #2
IIRC the "general rule" 7" rise 11" run
mdlbldrmatt135 is offline   Reply With Quote
Old 09-20-2007, 10:12 PM   #3
Extreme DIY'r Adk's, NY
Rewards Points: 272
"crap"enter
crecore is offline   Reply With Quote
Old 09-21-2007, 08:29 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Cedar?
What kind of cedar?
Well anyway it doesn't sound like anyone will fall very far.......you need a field skewable stringer/joist hanger.
Stubbie
Old 09-21-2007, 09:37 PM   #5
11" is the ideal run but I usually subtract or add the equal amount that you subtract or add from the rise except opposite.
Ex. If your rise is 7 1/4" then make your run 10 3/4".
You should be able to attach to the existing ledger. Perhaps scab on a piece of 1/2" plywood twice as wide as the existing ledger, then put another equal 2X behind the plywood and below the existing ledger. This will give you more room to work with.
Like this > :l (Dots being ledgers l being plywood)
Make sense? Of course you would have to face it with cedar.
jiggyjack is offline   Reply With Quote
Old 09-21-2007, 11:07 PM   #6
robertcdf's Avatar
Just use stair straps (simpson FHA18 or FHA24) nailed to the face and then covered with cedar.
robertcdf is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
Stair riser protection question JLam Carpentry 3 09-11-2006 04:28 PM
