Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-08-2011, 09:13 PM   #1
Electrician
stair molding help
Can somebody please tell me the correct way to find this angle? I've been trying to wing it but its NOT working and the supply is running short.
What I'm trying to do is run molding down the steps and then have it turn into the stringer. I did it once don't know how and it was months ago, so whatever I did I forgot.
I've posted two pics 1 of what I did and the other of where I'm stuck.
StackEz is offline   Reply With Quote
Old 10-08-2011, 09:42 PM   #2
Framing Contractor
stair molding help
Didn't we give you the correct advice last week on Contractor Talk?
sixeightten is offline   Reply With Quote
Old 10-08-2011, 09:52 PM   #3
stair molding help
looks like you are done
bluebird5 is offline   Reply With Quote
Old 10-08-2011, 09:53 PM   #4
stair molding help
they angle can be anything as long as they are the same. The stair angle is probably gonna be a 35 or 32 or something like that
Old 10-08-2011, 10:52 PM   #5
Electrician
stair molding help
i got ripped for askin on CT so i came over here. not that i care but if thats the response im gonna get i'll jus go elsewhere. Im an electrician with some knowledge of other trades just from seeing it done but im stuck on this one
Old 10-08-2011, 10:54 PM   #6
Electrician
stair molding help
that's the pic of the first landing, im tryna duplicate on the second landing
Old 10-08-2011, 10:56 PM   #7
Electrician
stair molding help
the angle of the steps...do i have to take that into consideration when makin my cuts
Old 10-08-2011, 11:13 PM   #8
stair molding help
take your speed square and place it on the existing trim and you can get the angle. There are 2 angles there on on the skirtboad of the stairs and one that goes against the exithing trim. They both look the same. If you don't have a speed square, take your tape measure and measure all three sides of the triangle and don;t worry about what the angle is.
Old 10-08-2011, 11:15 PM   #9
Mod
kwikfishron's Avatar
stair molding help
To find that angle I’d simply hold a piece of scrap down on the skirt running past the end of the wall and scribe that angle.
If that scribed angle happened to be 38 degrees then angle of the two pieces of trim would be 19 degrees each, half of the scribed angle.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-08-2011, 11:16 PM   #10
Framing Contractor
stair molding help
This is totally the wrong way to do this. This is finish work. Close is not good enough. If you let each piece run wild over each other, you can mark where the intersection is. Mark it at top and bottom, connect the dots, line up the angle of your miter box and voila!
molding over molding, Can it be done? jerry1977 Remodeling 3 07-27-2011 02:31 PM
positioning molding joetab24 General Discussion 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
