Stair Makeover - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-20-2007, 10:39 PM   #1
Stair Makeover
I have removed the carpet from my stairs and I would like to either add a thin layer of oak that I can stain to the risers and treads or alternatively paint them.
My problems are:
1)what is the rise / run requirements to keep the stairs in code , by my measurement the rise is 6 inches and the run (tread ) is 9 inches?
2) How on earth do I cut the overhand off and why is this necessary?
3) Can I use laminate as this is what I have on my upstairs and these are the internal stairs leading from the second floor?
The stair guys want $4000 to cover everything in oak but I cannot afford that. worse case I will be happy with a nice paint job and a runner.
clemkonan is offline   Reply With Quote
Old 09-23-2007, 03:25 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
See Stair question where Rise & Run is described to someone who is replacing. As for $400 that is not bad for putting a "Veneer" overlay over the existing Treads & Risers. A whole lot cheaper, then having the Stair guy make up a whole new stair structure, tearing out the old, and putting in the new.
who has "nice" stair edging? mattroos Flooring 8 09-07-2007 10:34 AM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
proper way to install laminate on stair KUIPORNG Flooring 3 11-21-2006 08:16 AM
Stair riser protection question JLam Carpentry 3 09-11-2006 04:28 PM
Brick fireplace makeover 'Andyman Remodeling 2 12-14-2005 10:22 PM
