Stair Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 09:22 AM   #1
stair help
what goes on first stair tread or riser
russ meyer is offline   Reply With Quote
Old 03-08-2012, 09:28 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Depends, whataya doin?
12penny is offline   Reply With Quote
The Following 2 Users Say Thank You to 12penny For This Useful Post:
JoeCanning (03-09-2012), Willie T (03-09-2012)
Old 03-08-2012, 09:37 AM   #3
i installed hardwood flooring and now i am going to install new traeds and risers to match. just wondering if risers help hold new tread down extra if installed on top.also is the correct overhang on tread 1 1/4 inch? thanx
Old 03-08-2012, 09:42 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
Tread first, with poly construction adhesive. I use 16ga nails in inconspicuous spots, then fill with wax stick.
Proper overhang is 1". I back my risers with strips of 1/4" ply, glued and nailed.
The Following User Says Thank You to 12penny For This Useful Post:
russ meyer (03-08-2012)
Old 03-08-2012, 09:46 AM   #5
thank you bought a house and tryin to get rid of all the "contractor grade" material and upgrade things and do it my self to save a buck.thanx again
Old 03-08-2012, 09:47 AM   #6
nice pic thats exactly what my wife wants and hopefully what my steps look like when i am finished
Old 03-08-2012, 09:58 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
Take your time....you'll be okay.
And thank you.
Old 03-08-2012, 11:11 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
The risers go on first as they nail or screw and glue to the back of the tread to help support the tread.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
kwikfishron (03-09-2012), woodworkbykirk (03-08-2012)
Old 03-08-2012, 11:14 AM   #9
Not so new
12penny's Avatar
Rewards Points: 520
I think the stairs are there, he's just covering them.
Old 03-08-2012, 06:17 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,264
adding on what jiju stated, nailing through the back of the riser into the back edge of the tread also eliminates movement which creates squeaks
woodworkbykirk is offline   Reply With Quote
Old 03-08-2012, 08:21 PM   #11
Stairguy
Millertyme's Avatar
Rewards Points: 508
Risers usually go in first. Also you want more overhang than an inch if you are putting scotia. 1-1/8 to 1-1/4" is the norm
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (03-09-2012)
Old 03-09-2012, 01:55 PM   #12
Old School
Willie T's Avatar
This is my favorite way.... Although I show only a small strip of wood on the bottom of the riser, you can leave as much as you want.
stair help-stair-const.-1.jpg   stair help-stair-const.-2.jpg   stair help-stair-const.-3.jpg   stair help-stair-const.-4.jpg
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
BigJim (03-09-2012), PaliBob (03-13-2012)
Old 03-29-2012, 06:23 PM   #13
Risers first, and if you want to make it look good, go with the pics above
Btw, don't cover the old stairs as 12 penny thinks you're doing. You'll end up with a lower riser at the top
mrgins is offline   Reply With Quote
Repair Stair Stringer sunshine54 Flooring 2 11-27-2011 11:06 PM
Laminate Stair nose agapediy Flooring 10 04-15-2011 12:27 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 07:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 01:31 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
