Stair Headroom Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 04:20 PM   #1
Stair headroom problem
At the top of our stairs the headroom doesn't meet the minimum code of 6'2". It is only 5'6". The stairs cannot be pushed into the room at the bottom any further as it has a bathroom under it with a toilet and window under the stairs. We can't go up at the top of the stairs at it would then run into the roof. The inspector won't sign off on things until we get the stairs fixed. What sort of options do we have to resolve this?
Clumsy Hamster is offline   Reply With Quote
Old 04-16-2011, 04:26 PM   #2
DIY staff
Rewards Points: 7,174
Can you provide a sketch or photo----old house ? More details please.--Mike---
Old 04-16-2011, 04:29 PM   #3
kwikfishron's Avatar
Rewards Points: 596
Can you post some pictures of the area?
Are you sure 6'2" is code in your area that seems pretty low.
kwikfishron is online now   Reply With Quote
Old 04-16-2011, 05:24 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
If you can't move the foot of the stairs the only thing left is to elongate the stringers and make the treads wider, that would push the top of the stairs back further and will give you more head room but it is doubtful that it will give you enough room. Also by elongating the stringers it will give you less head room in the bathroom below. If the bath wasn't under the stairs you could do several things.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-16-2011, 06:21 PM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
ask the inspector........
tcleve4911 is offline   Reply With Quote
Old 04-16-2011, 09:09 PM   #6
Framing Contractor
Who framed it?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-16-2011, 10:08 PM   #7
tcleve4911,
The inspector just said "good luck" He himself wasn't sure of how to do it.
Joe Carola,
Framing is from the 40s or later. We are not sure who framed it as it was purchased like this.
kwikfishron,
6'2 is minimum code requirements for existing stairs. Code typically calls for 6'8 but they make exceptions for existing homes.
jiju1943,
That is a great idea. I'll examine it to get a better idea. I'm afraid doing this will drop the headroom of the toilet below it to much and the possibly impact the window but we'll see.
I'll try to take some pictures and possibly a sketch so that it is easier to make out.
Appreciate everyones comments.
Old 04-17-2011, 04:52 PM   #8
Rewards Points: 1,596
Why is this an issue? If you own it, code wasn't an issue of sale. If you are selling it, I'd assume it'd be grandfathered as existing structure.
bob22 is online now   Reply With Quote
Old 04-17-2011, 05:04 PM   #9
waterman1971's Avatar
Rewards Points: 154
Do a landing at the elevation of the bath ceiling.
That will allow you to push the stair back as much as you require
waterman1971 is offline   Reply With Quote
Old 04-18-2011, 02:37 PM   #10
Here is a sketch of the layout. I apologize for it not being all that great and not to scale. Hopefully, this gives an idea of what we are facing.
Old 04-18-2011, 03:42 PM   #11
Old School
Willie T's Avatar
Yeah, you sure the inspector didn't say 6'-8"?
Willie T
Old 04-18-2011, 04:08 PM   #12
SteelToes's Avatar
Rewards Points: 150
Alt. Stairs
Alternating stairs...
Stair headroom problem-alternating-tread-stairs-9.jpg   Stair headroom problem-stairs.jpg
SteelToes is offline   Reply With Quote
Old 04-18-2011, 04:54 PM   #13
Rewards Points: 154
I am not sure how deep into it y'all want to get, but a dormer would fit the bill perfectly.
The Following User Says Thank You to waterman1971 For This Useful Post:
BigJim (04-18-2011)
Old 04-18-2011, 09:48 PM   #14
Yeah, we were kind of thinking the same thing. I think that all we could ever do is either a dormer or eliminate the bathroom. A dormer is well beyond our budget and we really don't want to eliminate a bathroom.
Old 04-18-2011, 11:23 PM   #15
Registered User
Rewards Points: 5,516
Could you turn after a landing part-way down? Adding a post at the inside corner and removing some floor space?
Pictures would really be helpful here, or we can keep guessing...... even a sketch. lol
Gary
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
