Stair Basics - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 05:56 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Stair basics
Hello folks. I'm framing my basement (slowly) and I'm planning ahead on the stairs. Currently I have the walls studded on both sides. My question is: drywall down below the stairs, then skirt boards over that followed by the treads and risers? I'm thinking I want to maintain 2X treads and carpet when finished.
If anyone has pictures at any points along the way, please post them.
Thanks in advance.
MikeKy55 is offline   Reply With Quote
Old 12-16-2010, 06:36 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Thanks in advance.
Check out this link
http://www.finehomebuilding.com/How-...aspx?channel=3
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-17-2010, 09:30 PM   #3
once you test fit the stringer and you're happy with it, you'll cut a 2X4 the same length and angles top and bottom, and screw it to the studs along the bottom of the stringer. this will be your "spacer" for skirts and sheetrock.
then you frame the stringers, screwing the two sides onto the spacers. then sheetrock down to the spacer. then skirtboards. your risers will be scribed tight to the skirtboards (they'll wind up going over the treads just slightly), then same with the treads.
good luck.
also, save yourself a lot of aggravation and buy one of these "how to build stairs" books on amazon.
wombosi is offline   Reply With Quote
The Following User Says Thank You to wombosi For This Useful Post:
BigJim (12-17-2010)
Old 12-18-2010, 11:19 AM   #4
MikeKy55's Avatar
Rewards Points: 254
Thanks for the info.
My stairs are already built and in place. I studded walls on both sides. The existing treads are 2X10's but every other one is curled across the 10" span. So I will cut new treads in the end.
So, if I understand correctly, attach a 2X4 across the studs at the same angle as the stringer and cut the drywall to match that followed by the skirt board? The skirt board and trim above it will be painted when I'm finished. What wood would be best for the skirts? plywood? , 1X's or other?
Old 12-18-2010, 06:24 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
I made my skirt from a 1X12.
Jim
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
