Stair Balusters - Dowel Or Screw? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-30-2014, 05:45 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Stair Balusters - Dowel or Screw?
If you were building stairs would do attach the balusters with screws or use dowels and glue?
Old 06-30-2014, 09:22 PM   #2
Rewards Points: 484
Worked with supposedly the premier stair guy in SE MA a month or so back. Balusters were put in with glue. No screws. Ron
ront02769 is offline   Reply With Quote
Old 07-01-2014, 07:53 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Inside, outside, square, round?
12penny is offline   Reply With Quote
Old 07-01-2014, 10:00 AM   #4
JOATMON
ddawg16's Avatar
I will be using square balusters with a plowed hand rail...so it looks like dowel and glue.
I'm inclined to think replacing a broken baluster will be easier using dowels and glue.
Thanks for the input guys
Old 07-01-2014, 10:06 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
Did you also get the insert for the plowed out portion. Never saw a reason to dowel them.
Old 07-01-2014, 10:22 AM   #6
JOATMON
ddawg16's Avatar
I'll dowel the bottom and nail the top....then use the insert.
Old 07-01-2014, 10:25 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
FYI...they make a bottom piece that's plowed like the top rail.
Old 07-01-2014, 10:29 AM   #8
JOATMON
ddawg16's Avatar
I made my own bottom....in my case, dowel will be much easier on the bottom.
BTW....Lehigh Valley? I know the area.....I lived in Allen Town for about 7 months putting in that Coca Cola plant.
Old 07-01-2014, 09:47 PM   #9
Dowels, takes longer, looks nicer!
TimothyJ is offline   Reply With Quote
Old 07-02-2014, 06:09 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
I'm in Bethlehem, out near the airport. Nice area to raise a family. 4 seasons, lots to do and good schools. I do miss hearing Pennsylvania Dutch though, seems to have disappeared since the mass migration from NJ and NY.
Old 07-02-2014, 01:39 PM   #11
hboogz's Avatar
Rewards Points: 97
out of curiosity, which type of dowel and glue will you use for this project ?
hboogz is offline   Reply With Quote
Old 07-02-2014, 02:58 PM   #12
JOATMON
ddawg16's Avatar
I'll most likely use standard dowels....like the type I would use in any woodworking...except the biggest one I can find. They are ribbed so the glue does not get squeezed out. For glue....that bottle of wood glue in my garage....titebond I believe...
The Following User Says Thank You to ddawg16 For This Useful Post:
hboogz (07-02-2014)
Old 07-02-2014, 03:18 PM   #13
hboogz's Avatar
Rewards Points: 97
Forgive the basic nature of my question, but where on the balluster would the dowel be installed? In other words, how does it eventually attach to the bottom plate and top rail ?
Old 07-02-2014, 03:25 PM   #14
JOATMON
ddawg16's Avatar
I've asked the same questions...
In my case I'm putting my balusters on top of a knee wall...so I'll mark and drill a hole in the knee wall...then cut the base of the baluster at the same angle as the knee wall...then drill a hole....well....actually, I'll drill the hole in the bottom first...deep...and then cut
On the top...since I'm using square balusters...the top hand rail has a plow....so the top fits in there. A little glue...couple of nails....done.
hboogz (07-02-2014)
Old 07-02-2014, 04:14 PM   #15
hboogz's Avatar
Rewards Points: 97
I see it now. Thanks for the explanation. Are you using a sliding bevel to catch the same angle of the ballusters as it descends the stairs ?
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 08:30 AM
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 09:17 PM
How to remove screw stuck in the wood? higv2000 General DIY Discussions 13 06-30-2012 01:40 PM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
stair balusters anthonyr Carpentry 5 05-15-2010 09:14 AM
