Stair Balusters - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 11:37 PM   #1
stair balusters
I would lik to change wooden baulesters to wrought iron, how do I begin?
anthonyr is offline   Reply With Quote
Old 05-14-2010, 04:33 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Anthony, This will not be legal if the new opening between balusters is greater than 4".
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-14-2010, 11:46 AM   #3
Rewards Points: 3,130
Perhaps, but not necessarily. The OP doesn't say where he lives. The circular stair kit I put up came with several different templates for drilling the steps to attach the balusters. Only difference between the templates was the spacing.
Old 05-14-2010, 06:49 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
are you re[lacing the handrail too?
if not what kind of balusters are there now?square top?pin top?
Millertyme is offline   Reply With Quote
Old 05-14-2010, 09:20 PM   #5
Wooden pin tops, we would like to darken handrail a bit.
Old 05-15-2010, 10:14 AM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
If you are not replacing the handrail, it may be tricky. The hole in the bottom of the rail are either going to be 5/8" or 3/4" depending on which baluster you have. The tops of the iron balusters are always 1/2". so you will need to find a way to fit them tight. They do sell special shoes that are made to pitch that you can use on bottom side of the rail and attach with a set screw. they also regular shoes on the bottom. The tread should have 3/4" holes drill in them. You will be able to use these hole again as long as you dont use any scroll style balusters. the scroll balusters might screw up the spacing and you will not be able to re use the holes.
Start by cutting out old balusters. Take a iron baluster and place the top part in the hole. Mark the bottom at the top of tread. Add 1/2" to the bottom of the baluster and then cut. i cut with a metal chop saw but i have also used a jigsaw with metal cutting blades, that works fine too. Fill hole with epoxy, gorrila glue, or pl400, slide shoes on first then slide in the baluster. drill the tread hole as deep as you can so you can put baluster in the hole, move into position and then slide it up all the way till it stops. Then tighten the set screw on the shoe.
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Interlocking pavers & stair leading to house amdspitfire Landscaping & Lawn Care 6 07-21-2008 04:30 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
