Stair - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 12:00 AM   #1
stair
what is the preferred slope of a stairway
guardiola is offline   Reply With Quote
Old 02-11-2010, 02:58 AM   #2
jlhaslip's Avatar
Rewards Points: 946
7 inch rise and a 10 inch run will give you a slope of 35 degrees.
6 1/2 x 10 is 33 degrees.
something around there should work. Stairs are not measured in degrees, but rise/run numbers.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 02-11-2010, 06:43 AM   #3
What he said, but actually, according to IRC R311.5.3. min tread depth is 10", max riser height is 7 3/4. And tolerances over the range of steps can't exceed 3/8". Generally, an accepted dimension for both tread/riser is 18", more is OK, less is usually not.
Old 02-11-2010, 10:06 AM   #4
removed
chaos232 is offline   Reply With Quote
Oak hand rail on existing iron stair railing dougworm Carpentry 8 05-03-2011 06:54 PM
Lighting for stair risers jweiner Electrical 2 04-06-2009 06:18 AM
Stair framing question stubborn1 Carpentry 6 01-19-2009 12:12 AM
Interlocking pavers & stair leading to house amdspitfire Landscaping & Lawn Care 6 07-21-2008 04:30 PM
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 06:54 AM
