Staining Over Finished Wood - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 11:36 AM   #1
staining over finished wood
Hi,
I have a light stained paneling issue. We recently bought a house with paneling in the den. The woodwork itself looks pretty, but wedon't like the finish. It looks like some sort of stained varnish someone put on the wood with a brush and the stain is light. We want to darken the wood, but do not want to strip. Would you know of any techniques that we could use to darken the wood over the old finish?
I have heard there is some sort of gel one can apply over it with a rag??? Would you know what that is?
Thank you much,
Isabel
Isabelbr is offline   Reply With Quote
The Following User Says Thank You to Isabelbr For This Useful Post:
einandyno (07-11-2011)
Old 01-21-2011, 01:42 PM   #2
Rewards Points: 5,336
Post some pictures of the paneling. Are you sure it's real wood and not a wallpaper design on a luan substrate?
If it's real wood, you can sand it a fine grit(150 or 220) and try the Minwax Poly shades. It's a combination stain and polyurethane. The more coats you put on the darker it gets.
Try to use it on some scrap wood before diving into the paneling. Application takes a bit of practice and you can see if you like the results.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Isabelbr (01-21-2011)
Old 01-21-2011, 05:41 PM   #3
Thank you so much for your reply. Yes, it is real wood. It is an old home with really nice woodwork, but we suspect the paneling in the den was done in the 1960s or 70s. It immitates Tudor panelings, but has this really ugly yelowish stain.
I will try what you suggest on a piece of the builtins we are desmanteling. It is made of the same wood and finish. I will also try to go to the house this weekend and take a picture.
Thanks again,
Isabel
Old 01-21-2011, 05:55 PM   #4
Thanks again,
Isabel
If you're sure it's real wood, there's no need for a photo.
Ron
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 10:27 PM
new process or product for re staining or painting wood cabinets efox Painting 1 11-20-2009 03:35 PM
Staining new treated wood porch Designman20 Building & Construction 1 10-10-2007 07:25 PM
Wood staining nightmare clamityjane Interior Decorating 8 08-22-2007 09:16 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
