#1 |
staining hardwood risers
what is the best process/way to refinish my hardwood step risers?
#2 |
Your header says stain, your question says refinish, which is it?? If previously finished(poly or other), the old finish needs to be removed and the wood sanded as prep for stain. To simply refinish, lightly sand the finish and apply new finish.
Minwax makes a colored finish called Polyshades, available at home, hardware, paint stores. I am not a big fan of it because if you get runs or the finish pools, it will be darker and obvious. It does eliminate the need to strip the old finish, just sand lightly. |
| Display Modes | |
| Question about staining hardwood. | Scotch | Flooring | 4 | 03-10-2011 08:47 AM |
| Staining Hardwood | Alcarte | Flooring | 4 | 02-02-2011 09:37 PM |
| Is staining hardwood floors the best way for me to go? | AndreaMB1978 | Flooring | 7 | 07-27-2009 03:08 PM |
| Staining treads, painting risers | QueenL | Building & Construction | 5 | 04-13-2008 10:23 PM |
| Questions on Staining Hardwood! | noodlesalad | Flooring | 2 | 12-15-2006 10:17 AM |
