staining cabinets need pro pointers
I recently purchased a product called Penofin Verde, which is a penetrating oil finish. It contains no petroleum distillates, has no odor, and is made of Brazilian Rosewood Oil.It comes in many shades and goes on more evenly than traditional stains and finishes. Thirty minutes after application, you wipe off the excess and the results are amazing. Even if not evenly applied, when the excess is removed the coverage is flawless in its uniformity. There is no other oil or product that I can compare this to. I will never use anything else again. I have used it on pine, cherry, and cedar with equal results. Another plus is that the same formula is for both indoor and outdoor use. Hope this helps.
