Stain Or Paint - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 11:18 AM   #1
Rewards Points: 27
stain or paint
I just finished putting a deck in my patio and was wondering what is the best way to finish it off. I used pressure treated wood and didn't know if I could use a strain for it or should I paint it.
woodenSpoon is offline   Reply With Quote
Old 01-13-2014, 11:22 AM   #2
Gymschu's Avatar
Rewards Points: 932
Stain.
Gymschu is online now   Reply With Quote
Old 01-13-2014, 11:23 AM   #3
Rewards Points: 14,010
Going to have to go back and add your location to your profile to even guess how long your going to need to wait before doing anything.
That new wood is soaking wet and will need to dry out.
Seal it now and your sealing in the moisture and it will mold up from then on.
Pressure treated does not hold paint as well as stain and when it does start to fade if it's stained your not spending days sanding and scraping peeling paint.
ddawg16 (01-13-2014)
Old 01-13-2014, 11:27 AM   #4
Jmayspaint's Avatar
Rewards Points: 534
Stain is going to be easier to maintain. Painted decks almost invariably peel and become a maintaince nightmare. If you want a solid color use a solid stain.
New treated lumber needs time to dry/cure before applying any coating. Generally it needs 3-6 months or more of drying time, and proper prep before any coating/stain can be expected to succeed.
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Old 01-13-2014, 01:02 PM   #5
Rewards Points: 27
Wow. I did not know it took that long to completely cure. I live in Houston texas so it shouldn't take too long for the wood to dry since the highs now are around 70 degrees
Old 01-13-2014, 03:35 PM   #6
Gymschu's Avatar
Rewards Points: 932
I like this stuff for decks………more of a clear coat……you can get it in redwood, cedar, or clear tones.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Stain or paint on sideing. Which is better maddog1 Painting 7 12-12-2012 01:29 AM
paint over mystery deck stain? denemante Painting 3 09-20-2012 08:05 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
