Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-29-2007, 11:34 AM   #1
Default Squeaky Laminate Floor
About to sell a house. Floor is squeaky right in front of the fridge, probably because it's a high traffic area. I have access from the basement since it's unfinished. I think the squeak is from the plywood not being probably secured onto the OSB. OSB is 23/32 thick. Plywood is probalby a 1/4 thick. Will probably drive screws from bottom to try to secure down the plywood. Any more ideas?
handy man88 is offline   Reply With Quote
Old 03-29-2007, 12:00 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That's may stop the squeak, I would suggest that there be some weight on the area to push it downward... when you set the screws from underneath.
Obviously, be careful with those screws...
- Build Well -
Old 03-29-2007, 12:02 PM   #3
Good point. Thanks. What length would you use for the screws?
Old 03-29-2007, 01:31 PM   #4
Try to figure out the thickess of your floor sheathing (usual thickness is 3/4"). Then add the thickness of the 1/4" plywood you said is on top of that.
So for example: let's say it is 1" total thickness Use a 7/8" length screw...
- Build Well -
Old 03-29-2007, 01:48 PM   #5
I checked last night, and I think the sheating is 23/32 (.7188). I'm assuming the plywood is 1/4 (.25) which makes .9688 total. 7/8 should work.
More On This Topic
Hi! I’m Melanie McLeroy with Taurus Training for Expert Village, and we’re going to work with a Bracco Italiano also known as an Italian setter. True to her nature, sweet Bella is very, very kind, very sweet and very energetic. So this... Read More »
Hi! I’m Melanie McLeroy with Taurus Training for Expert Village, and we’re going to work with a Bracco Italiano, also known as an Italian setter. We’re trying to teach this Bracco Italiano how to sit. Now in the first video we... Read More »
Hi! I’m Melanie McLeroy with Taurus Training for Expert Village, and we’re going to work with a Bracco Italiano also known as an Italian setter. We’re moving on to teach this Bracco Italiano how to lie down. Now, it’s easy to... Read More »
Hi! I’m Melanie McLeroy with Taurus Training for Expert Village, and we’re going to work with a Bracco Italiano, also known as an Italian setter. Now we’re going to work on teaching this Bracco Italiano or Italian Setter to come. Now... Read More »
Hi! I’m Melanie McLeroy with Taurus Training for Expert Village, and we’re going to work with a Bracco Italiano also known as an Italian setter. And it’s time to teach this Bracco Italiano how to walk nicely on a leash, how to heel. Now... Read More »
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 06:06 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 31 01-03-2009 01:33 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 10:07 AM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-21-2007 12:44 AM
Horizon Laminate Floor from China Kelvestto Flooring 3 09-20-2006 01:19 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
