Splitting Slabs - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 07:08 PM   #1
splitting slabs
i constructed a chest on chest dresser for my son a year ago....the side panel (20 inch wide slabbed oak panel) split just the other day... i used minwax stain sealer on this slab ....but may not have gotten enough on the inside of the unit...could this be the cause of the splitting....the dresser was sitting next to a window at the time of the fractrure...would appreciate some input......thankx
rfrf49 is offline   Reply With Quote
Old 01-02-2011, 03:43 AM   #2
starkenwolf's Avatar
Several considerations on splitting wood....had a guy who custom built an entire kitchen's cabinets, brought them 800 miles and installed them...they fit perfectly. BUT, the wood was not aged completely and thus, the from the heat being on in the winter- cracked and warped all to heck in about 3 yrs time......they dried out rapidly with the forced air heat and that was that.
Dunno if that applies here, but furniture grade wood should be cured a minimum of 2 years.
starkenwolf is offline   Reply With Quote
Old 01-02-2011, 06:32 AM   #3
The wood i used was kiln dried rough cut lumber...sat in my rack for about eight months after that befored use....could be the answer to this problem! Thanks..
Old 01-02-2011, 07:55 AM   #4
DIY staff
Rewards Points: 7,174
Wood expands and contracts with the seasons---Wide solid wood panels need to be able to slide as the size changes---the back edge of the dresser side panel should have been attached with screws driven into oval holes---
Wide cabinet sides and backs are seldom made of solid wood --typically a stile,rail and panel system is used to avoid the issues of expansion and contraction.--Mike--
Making a patio from broken granit slabs need help BJLower Tiling, ceramics, marble 9 09-15-2014 12:15 PM
9'x7' Patio 24"x24" slabs. Prep work needed. the punisher Landscaping & Lawn Care 1 08-30-2010 03:49 PM
How can I insulate precast concrete slabs, and prevent mold of coming back? Ivance Building & Construction 3 12-18-2009 10:27 AM
hardwood tongue is splitting with nailer atomilano Carpentry 10 05-04-2009 08:05 AM
How can I smooth my bumpy slabs in preparation of epoxy paint/coating? joeyboy Painting 5 02-13-2008 07:12 PM
