Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-19-2011, 10:10 PM   #1
Splinters/ Sanding a wood deck
I have a large (500sf) wood deck that needs to be re-stained. I started by pressure washing the deck but I used a turbo tip on my power washer and caused many of the boards to splinter. This weekend I rented a floor sander and got my butt kicked to the point that I just returned it. No matter what grit paper I used, it was just impossible to get the job started let alone completed. That being said, what is the best way to get the splinters off so that I have a smooth surface to stain? I can't see myself on the floor with an orbital hand sander for 2 days smoothing the deck. Any suggestions would be greatly appreciated.
adam3477 is offline   Reply With Quote
Old 06-19-2011, 11:25 PM   #2
If you're not sanding them, you're replacing them or hiring someone else to sand them.
Ron
B. Franklin 1759
Old 06-20-2011, 12:49 AM   #3
I have the same problem Adam. I was going to start a thread too, asking if it's possible to turn the boards over (since I haven't ruined that side with the pressure washer).
But there must be a reason that it can't be done because I haven't read about anyone flipping them over.
Barb
gma2rjc is offline   Reply With Quote
Old 06-20-2011, 06:01 AM   #4
sdsester's Avatar
You can flip them over if they are intact and decent looking on the flip side.
What kind of sander did you try? Had you allowed enough time between pressure washing and sanding for the wood to dry out?
sdsester is offline   Reply With Quote
Old 06-20-2011, 08:53 AM   #5
Barb
Yes, you can flip them over, but there will be an installation pattern on the back side that will need to be sanded to get off.
And we're back to the sanding issue.
Why not just leave them in place and let someone who knows how to use the sander do the work?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
gma2rjc (06-20-2011)
Old 06-20-2011, 04:07 PM   #6
Another thing to consider is that the edges along the bottom of the boards may have drip marks on them from the sealers or whatever has been applied to the deck over the years.
I contacted a guy who had an ad in the paper for floor sanding. I asked if he would come over and sand my deck. He said it wouldn't be worth his time and gas money and that I wouldn't want to pay him $400 to do the job.
I probably would have paid that much because there are 2 decks equalling just under 550 sq. feet.
But if someone were to sand it with one of those big floor sanders, would the heads of the screws tear up the sandpaper?
Barb
Old 06-20-2011, 04:27 PM   #7
Barb
You would have to countersink every fastener below the surface, deep enough to avoid the issue. No professional would even take his machine out of the truck otherwise.
Ron
B. Franklin 1759
Tags
deck staining, deck striping, sanding, splinters, wood deck
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Wood deck over a concrete patio mkam80 Building & Construction 3 12-28-2009 06:45 PM
Deck Prep: Sanding > Powerwashing jellydonut Painting 9 07-21-2008 10:48 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
deck sanding, varnishing/protecting mcvane Building & Construction 3 05-09-2007 10:48 PM
