Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-28-2009, 04:37 PM   #1
splicing ceiling joists
I need ceiling joists 20', but can only 16'. Can I splice two boards to get the length?
baas1219 is offline   Reply With Quote
Old 06-28-2009, 05:12 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
What size boards?
Short answer - no - not really
There are 20' joist available at most lumber stores - even HD/Lowes
I went with I-joists on a 17' span for added strength - walk up attic
Old 06-28-2009, 07:18 PM   #3
Custom Cabinet Maker
Agree Dave: Baas if you need 20' then just get TJI's easier, lighter,straighter, and probably cheaper
skymaster is offline   Reply With Quote
Old 06-28-2009, 07:27 PM   #4
Framing Contractor
You can get 20' 2x6, 2x8, 2x10, 2x12 joists at any lumberyard. Forget I-joists and spending the extra money.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-28-2009, 09:08 PM   #5
Scuba_Dave's Avatar
I-joists weren't that much more then the 2x12 x 20'
They were lighter, stronger & easier to install
Old 06-28-2009, 10:08 PM   #6
2 fingered typer
woodnthings's Avatar
20 feet is a hellofaspan if there is a floor load above. If this is a garage with "no load" above, remember how stuff gets stuck up above the rafters? heh..heh What's your application here? bill
woodnthings is offline   Reply With Quote
Old 06-28-2009, 11:17 PM   #7
Framing Contractor
You have to be careful when using I-joist for ceiling joists because you can't just cut the top angle on the I-joist to follow the top of rafter beyond the inside of the wall. 2x's you can.
Scroll down to the bottom left on page 12.
http://www.kentinternational.ca/broc...System/TJI.pdf
Joe Carola
Old 06-29-2009, 12:45 PM   #8
Building codes guy, Mod
thekctermite's Avatar
Without the assistance of a structural engineer a splice in the span is a big no-no. You can get 20' lumber at nearly any good lumberyard.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 06-29-2009, 09:59 PM   #9
Scuba_Dave's Avatar
Ah, I had a walk up attic above that
So they were a ceiling joist & a floor joist
I think I'd be inclined to install a double top plate across the I-joists & then the rafters
Good point
Old 06-29-2009, 10:48 PM   #10
You need to specify the use for these. What loads they will carry? Partition walls under the joists?
The post is too vague to be answered.
Ron
More On This Topic
Hi! I'm Steve Chubin at Steve's Sewing and Vacuum Center in King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. Here we have a electric broom. An electric broom is generally for people who do not want a canister vacuum but... Read More »
Hi! I'm Steve Chubin and Steve's Sewing and Vacuum Center in King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. On a canister vacuum, when going from room to room, it is nice because everything is on the canister and is in... Read More »
Hi! I'm Steve Chubin at Steve's Sewing and Vacuum Center in King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. Here we have things that we would put inside your vacuum bag to keep your vacuum smelling good. As we talked... Read More »
Hi! I'm Steve Chubin at Steve's Sewing and Vacuum Center in King of Prussia, PA and today we are here to discuss how to buy a vacuum cleaner. Today we are going to talk about when you walk into a vacuum store which I would prefer you walk in to, you... Read More »
garage ceiling joists josh123 Carpentry 6 07-15-2009 12:07 AM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 11:44 PM
hanging ceiling above the joists?.... mben Building & Construction 18 04-01-2008 05:47 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
