Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-11-2005, 03:03 AM   #1
DoAll
Thumbs up
spindle spacing
I'm building some new balusters /w spindles anybody know the spacing codes ? thanks
jibber is offline   Reply With Quote
Old 11-11-2005, 05:57 AM   #2
jproffer's Avatar
spindle spacing
I know the spacing codes where I am. Before spending a bunch of money building them out of code though, you should check with your own building dept.
Code where I am is 4". Actually, I guess in theory, it's 0.001" LESS than 4". It has to be made so that a 4" sphere can't pass betweem them anywhere. So if they're turned, and you make it so the top and bottom are a little less than 4" apart, it'll fail in the center where they're turned down smaller.
jproffer is offline   Reply With Quote
Old 11-11-2005, 10:05 PM   #3
Carpenter
DecksEtc's Avatar
spindle spacing
Code here is 4" too. Personally, I space all my balusters at 3 1/2" to far exceed code - I never have to worry about shrinkage either.
Terry
DecksEtc is offline   Reply With Quote
Old 11-12-2005, 02:40 AM   #4
jproffer's Avatar
spindle spacing
Didn't we discuss this once on the "other side":D ...I remember someone (presumably you Decks) saying they space all spindles 3.5 to allow for shrinkage, turned sections, etc. Had a couple calculators floating around to get the correct spacing with equal end spacing ...hmmm...maybe I'll look for that tomorrow..er..I mean today:o
Old 02-18-2007, 08:59 PM   #5
spindle spacing
The old ones are loose and in need of refinishing and I want to start from scratch with the whole railing... anyone dont this before ...would appreciate the input. There is also a simple formula for finding the correct spacing between your spindles... and its pretty easy ( even for a chick...lol )
lorelei is offline   Reply With Quote
Old 02-18-2007, 09:30 PM   #6
jproffer's Avatar
spindle spacing
You'll get better answers if you start a new thread.
There's no magical formula for spindle spacing. You need to find out what code requires where YOU live and plan accordingly. The number they give you is maximum space, not center to center.
shingle seam spacing fredhedd Roofing 7 04-08-2009 07:52 AM
rafter spacing Clutchcargo Building & Construction 5 08-11-2007 03:14 PM
Sonotube spacing billinak Building & Construction 2 05-03-2007 05:31 PM
Undercabinet lighting spacing wbjdmd Electrical 3 11-12-2006 09:55 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
