"SPF" Frm Home Depot - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 10:24 AM   #1
Rewards Points: 150
"SPF" frm Home Depot
I am going to make a small bookcase for my son's room - 12" deep. I was going to use 1x12 pine boards. My local HD does not have pine this wide...they suggested a "Spruce-Pine-Fur" board instead. It is significantly cheaper than a pine board. Are these any good? They are also solid wood, I'm guessing they just might be a little inconsistant.
joemontana16 is offline   Reply With Quote
Old 06-25-2011, 10:37 AM   #2
Civil Engineer
Rewards Points: 4,584
Typically when I make furniture I glue up panels when I need to go 12 inches wide. This way I can use 3/4 inch thick stock that is typically anywhere from 4 to 6 inches wide. Course I generally work in cherry, maple or walnut, but the same principal applies to pine.
SPF is typically construction grade lumber. I don't know how you plan to finish the piece, paint, stain, varnish etc., but construction grade lumber is not going to look too good if you plan to oil, stain or varnish. You might want to go to a real lumber yard to get your wood.
Daniel Holzman is online now   Reply With Quote
Old 06-25-2011, 10:44 AM   #3
A Little Of Everything
Rewards Points: 1,364
SPF is okay. A lot of people make "crude" furniture out of it. If it's at Home Depot, its quality is going to be pretty inconsistent. That's okay, provided you carefully select your own boards.
Any 1x12 boards - in pine or spf - aren't going to provide much strength & support as shelves.
Have you considered using 3/4" plywood? If you've got a table saw you can cut it down. It'd be much stronger, and look better (assuming you buy a decent plywood).
DrHicks is offline   Reply With Quote
Old 06-25-2011, 11:13 AM   #4
Rewards Points: 150
Thanks guys. I'm just looking for simple and moderately inexpensive way to make a small 6 cube bookshelf. The longest span will only be around 2 feet. I'd be afraid that plywood would look rough as well. I chose pine because I thought it would be easier to work with than say oak (and less expensive).
Old 06-25-2011, 11:40 AM   #5
Any reason it has to be 12" deep?
That said, you should be fine with SPF. Just don't expect it to look or perform like a top-end hardwood bookshelf - and you're obviously not.
Old 06-25-2011, 11:34 PM   #6
Rewards Points: 5,336
Home Depot sells the glued up boards to 24" wide and 48" long. If you can't get the 1x12" pine, these will work fine. They will actually be more dimensionally stable.
Ron
B. Franklin 1759
Old 11-20-2011, 09:05 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
true. the laminated boards are very strong and stable, as they are made up of several narrower strips which have the grain direction alternated.
if your going for simple paint grade 3/4 mdf will work fine as opposed to melamine which has probably the weakest strength rating
woodworkbykirk is offline   Reply With Quote
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 09:03 PM
Is there a "high class" home depot? njhomer General DIY Discussions 28 12-06-2011 12:08 PM
Home Depot $10 off $100 online coupon mglc General DIY Discussions 0 08-16-2010 11:20 AM
Do places like home depot deliver on the spot? Red Squirrel Off Topic 2 05-17-2010 05:54 PM
