Speckling Plywood Joints - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 12:37 AM   #1
Speckling plywood joints
Can quick dry spackle be used seams when plywood panels are joined together?
Pranasea is offline   Reply With Quote
Old 01-12-2012, 12:43 AM   #2
Retired carpenter
Yes, but don't expect those joints to become invisible.
abracaboom is offline   Reply With Quote
Old 01-12-2012, 12:48 AM   #3
Rewards Points: 2,202
And they may crack if things shrink as they dry or shift slightly,
What is this for?
mae-ling is offline   Reply With Quote
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 07:47 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
