Spanning 18' With 2x6 - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 12:01 AM   #1
Rewards Points: 180
spanning 18' with 2x6
my roof is almost completed, and I'll be putting up the new ceiling soon. The 1937 redwood ceiling supports where removed and replaced with new 2x6 doug fir.
They aren't going to work. I have the old redwood 2x6's left over and was going to sister them with the new 2x6's
Would this solve the problem or should I sandwich in 3/4" plywood as well?
I plan on using the attic as storage, won't be very heavy just boxes of household stuff.
Thanks...
KarlJay is offline   Reply With Quote
Old 11-06-2010, 05:22 AM   #2
Framing Contractor
Thanks...
Are you working with approved plans from the town and building permits?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-06-2010, 10:26 AM   #3
Rewards Points: 180
No, I'm just fixing / replacing what was there before. A few of them had some rot. The roof had 1 small vent at the rear of the house and I think that was part of the problem. It didn't sag or move before. I think the problem is the wood up there before was old growth redwood and new wood doesn't compare.
Old 11-07-2010, 02:51 PM   #4
Rewards Points: 5,336
Is this 18 feet of unsupport 2x6 or is there a wall under this span that bisects it?
Ron
Old 11-07-2010, 11:04 PM   #5
Rewards Points: 180
Unsupported. My two easy choices would be to sister in another 2x6 sandwiched with 3/4 plywood. or just sister a 2x6.
The real question is what does it take to span 18'
The load will be storage, the roof is all hip and valley.
Old 11-08-2010, 12:24 AM   #6
jlhaslip's Avatar
Rewards Points: 2,872
play with this link for a little bit.
http://www.awc.org/calculators/span/...eversecalc.asp
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-08-2010, 10:55 AM   #7
Rewards Points: 180
Yeah, I saw the online tables and calc pages, but didn't see anything for 4x ceiling joists. It looks like 2x8 would work. Kinda wanted to use the 4x. They also don't have 8" oc. I have 16" oc now, going 8" oc would be pretty easy.
Since I still have the old ones and they worked, I think I'll just put them back where they were and make some bigger replacements for the one or two that are damaged.
Old 11-09-2010, 01:44 PM   #8
Punk
TuscolaMatt's Avatar
Rewards Points: 85
another idea - you could use 6" 14ga perlins - plenty strong...
Visit the PARTYBARN!
TuscolaMatt is offline   Reply With Quote
Old 11-09-2010, 03:29 PM   #9
There has been no mention of 4x anything.
Ron
2x6 spanning 18' is this going to be a problem? KarlJay Roofing/Siding 3 10-18-2010 09:50 PM
LVL beam spanning 30 feet? Colorado Steve Roofing/Siding 15 12-31-2009 11:16 AM
Spanning a ceiling lowery Building & Construction 5 03-15-2009 07:50 AM
