Spackle Or Joint Compound? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 12:51 PM   #1
Rewards Points: 89
Spackle or joint compound?
Does this require spackle or joint compound?
Fly_on_the_wall is offline   Reply With Quote
Old 02-02-2014, 12:54 PM   #2
Gymschu's Avatar
Rewards Points: 480
Joint compound after removing all the loose stuff and priming with Gardz primer.
Old 02-02-2014, 02:01 PM   #3
Rewards Points: 13,296
Spackle is for filling small nail holes.
Looks like someone removed some trim without cutting the paint line first.
Old 02-02-2014, 09:35 PM   #4
firehawkmph's Avatar
Rewards Points: 1,822
Looks like someone removed some trim without cutting the paint line first.[/QUOTE]
Backsplash removal.
Mike Hawkins
firehawkmph is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 06:09 PM
Use joint compound, spackle, something else?? tracyballard Carpentry 0 06-08-2010 11:39 PM
Used spackle instead of joint compound on a wallboard repair--help TytusDwn General DIY Discussions 4 10-25-2009 04:43 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Joint Compound Vs. Spackle Rze Painting 5 09-15-2007 12:09 AM
