Source For Trim Rings? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 08:08 AM   #1
Source for trim rings?
I have a cabinet that I'm going to use to house a TV and home theater components. I want to cut a 2" circular opening in the back panel to pass the cables and power cords through. To hide any roughness from the holesaw cut as well as protecting the cords from chafing, I'd like to finish the opening out with a plastic trim ring.
Can anyone suggest a source for such rings as I've not had any luck at all with online searches.
Thanks.
Michigan Dawg is offline   Reply With Quote
Old 07-07-2010, 08:20 AM   #2
the Musigician
DangerMouse's Avatar
Electrical friction rings (bushings) would be ideal for your purpose.
Two pieces will screw together right through the 2" opening perfectly.
DM
Old 07-07-2010, 08:33 AM   #3
Rewards Points: 378
Did you try McFelley's? I think I hve seen some brass ones.
fireguy is offline   Reply With Quote
Old 07-07-2010, 11:06 AM   #4
Rewards Points: 1,596
look at these perhaps:
http://www.rockler.com/CategoryView.cfm?Cat_ID=200
bob22 is online now   Reply With Quote
Old 07-07-2010, 11:42 AM   #5
Thanks to All!
Gentlemen, your suggestions were spot on and have definitely helped me. It seems the magic word was "grommet" while all I could think of to describe what I wanted was "trim ring".
Thanks again for the fantastic suggestions.
Old 07-07-2010, 12:44 PM   #6
the Musigician
What I showed costs around a dollar or two and is required by code for MY purpose, and is likely the correct piece to protect your wires as well as it is curved all around the opening. (Though probably not required by code in your case.)
DM
Old 07-07-2010, 02:15 PM   #7
gmhammes's Avatar
Call me cheap but you could also use 1/4 or 3/8 inch flexible black split loom depending on the thickness of the board your cutting the hole out of. you would only need 6-12 inches at most. Just an idea that i've used before on a few things.
http://www.cabletiesandmore.com/blackloom.php
gmhammes is offline   Reply With Quote
Old 07-07-2010, 04:38 PM   #8
Rewards Points: 117
If I understand correctly, they have plenty of options in the electrical section at Lowes (metal and plastic, and several different diameters too).
RickDel is offline   Reply With Quote
Toilet wax rings - plain wax? reinforced? with/without flange? How do you decide? lazzlazz Plumbing 0 05-16-2010 11:10 PM
Multiple Outlets From One Source (14-2) J.A.M Electrical 5 02-08-2010 07:39 PM
AC Condenser source of ignition? hrjrkr HVAC 4 09-16-2009 11:33 AM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 04:37 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
