Soundproofing Rooms With Dropped Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 01:57 PM   #1
Rewards Points: 18
I have an office which has dropped ceilings with 2x2 ceiling tiles. The sound problem is so bad that when someone talks in one room you can hear them 2 rooms down like it's a cubicle. My walls go up to the dropped ceiling and stop. I'm thinking that the best solution would be to have an actual ceiling installed instead of the dropped ceiling, and then all the wires and pipes running through the ceiling will be accessible through an attic/crawl space instead of by pushing up the ceiling tiles. I spoke with an engineer and he said he would just use batt insulation over the ceiling tiles. But I'm concerned then it will no longer be possible to push up the ceiling tiles to get to all the pipes and wires. I see they sell sound resistant ceiling tiles like this (http://www.asistorefront.com/p-276-m...d-install.aspx) but I don't know if the results justify the huge price. Any advice?
america2 is offline   Reply With Quote
Old 05-22-2013, 09:08 AM   #2
Too Short? Cut it Again!
Have you consulted an actual accoustical engineer or architect specializing in such things? I would start there before second guessing what might work.
Old 05-22-2013, 10:04 AM   #3
MJ Force's Avatar
Rewards Points: 150
I renovated a 300 seat pub in a hotel with rooms above the drop ceiling. Code required us to install FireGuard Cieling tiles (2'x4'). We also added 5/8" FireGuard drywall panels (2x4') ontop of those and acoustic insulation. The only sound transfer was low frequency when a band was playing in the pub. The noise was tolerable.
MJ Force is offline   Reply With Quote
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
Dropped ceiling tiles? CooperChloe Building & Construction 10 02-09-2009 08:31 AM
Dropped ceiling duct work. rusty model a HVAC 9 11-15-2008 08:58 PM
Horizontal drywall w/ dropped ceiling ClnlBrahm Drywall & Plaster 2 09-02-2008 12:38 AM
