Sound Proofing - Using MDF Under Wooden Floorboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 02:12 AM   #1
Sound proofing - using MDF under wooden floorboards
Hi
I have bought a top floor flat/ apartment in a house conversion. It is victorian so 100+ years old. I am installing engineered wooden floors onto the current wooden floor. I was thinking of laying MDF in between to help as a sound insulator before using an underlay. My carpenter says this wont help. Although i have it in my current flat. It seems to work where I live now, as my neighbours dont complain. Although in my current flat the base floor is concrete. He says MDF on wooden floors don't help with the noise reduction. I cant seem to find any arguments for or against this.
Can anyone offer any suggestions.
Thanks you
rachel111 is offline   Reply With Quote
Old 01-16-2014, 07:09 AM   #2
Rewards Points: 13,732
http://www.soundproofingcompany.com/...oofing-floors/
rachel111 (01-16-2014)
Old 01-16-2014, 11:13 AM   #3
Rewards Points: 153
MDF under the flooring won't help significantly. The sound will be going through wood(MDF) then wood (floorboards), and won't be reflected back or absorbed. Sound reduction in the situation you're describing is expensive, involved, or both.
Good luck!
eandjsdad is offline   Reply With Quote
The Following User Says Thank You to eandjsdad For This Useful Post:
will a higher r-value equate to more sound proofing diyer111 Insulation 1 09-03-2012 09:36 AM
Sound proofing HVAC return duct JayBird HVAC 8 07-27-2012 12:25 AM
No sound from speakers on rear projection tv chewizzle2k9 Electrical 4 11-06-2011 09:42 PM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 03:44 PM
Heating/cooling/sound proofing a new home theater Neonblue HVAC 1 03-07-2010 12:19 PM
