Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-02-2009, 10:23 PM   #1
Default Solution for sagging joists
Our ceiling joists were sagging. My wife wanted a cathedral ceiling, but after reading numerous posts on this forum I realized that probably wasn't going to work out.
So we decided to keep a flat ceiling. The contractor was adverse to cutting out the old joists (for fear of the walls splaying out).
But the old joists were sagging as much as an inch, and they were on 24 inch centers.
We ran an LVL the 24' length of the room and jacked up each joist and tied it to the LVL with hurricane clips. After that we screwed 1x4 furring strips on 16" centers across the joists and installed shims as necessary. After we got the joists jacked up and clipped on the room looked like it had a new ceiling. The transformation was dramatic. The LVL cost $300, and the guy who did the calculations on sizing them said he wanted the sale but a truss would probably be cheaper. We went with the LVL anyway for scheduling (they were in stock and we were already there).
The drywall is up now, and it looks good. There's a low spot that we didn't find, but hopefully it won't be too obvious once everything is finished.
pyper is offline   Reply With Quote
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
Hi! This is Dr. Erik Sorbo on behalf of expertvillage.com. Today we’re going to be talking about proper posture and some exercises that you can do to help strengthen your spine, and keep it working the way it should. A very simple stretch you can... Read More »
All right, so the first step to making sure your suspension is properly setup is setting the amount of sag that you have. Sag is the amount of suspension that you're using, just static at rest. The proper way to really get a good measurement of sag, is... Read More »
Making a floor in a garage. What size floor joists? GD73 Building & Construction 2 07-19-2009 08:07 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 10:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 08:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 02:48 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
