Solid Interior Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 09:22 PM   #1
solid interior doors
If i am replacing hollow core doors with solid pine doors from HD can i use the existing jambs?
BG93245@YAHOO.COM is offline   Reply With Quote
Old 02-24-2008, 02:42 PM   #2
Custom Cabinet Maker
Yes, however if you currently have 2 hinges then I would add a third, screws will have to be longer and I would put at least one in each hinge thru jamb and into the framing.
skymaster is offline   Reply With Quote
Old 02-24-2008, 02:59 PM   #3
Thanks, I was thinking kinda along that line into the framing but I did not see the third hinge but that makes sense for weight. I recently stumbled on to this web site i do like the look of there 6 panel oak door and the price seems resonabile enough i will be putting carbonized bamboo flooring in the hallway i guess they will go together???. any thoughts
distibution.http://nicksbuilding.com/Oakl_int_wood_doors.htm
Old 02-24-2008, 03:55 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Good Advice for this.
- Build Well -
Old 02-24-2008, 06:59 PM   #5
Thank you Sir Atlantic :}:}
gaps between solid treads & skirt boards shotdown Flooring 9 08-02-2009 10:43 AM
Installing solid hardwood foor ?? Grayroc k Flooring 1 12-29-2007 07:17 PM
torchon roof doesn't seem solid algernon Roofing/Siding 1 02-20-2007 10:01 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 08:23 AM
Trimming Solid Door allen1466 Building & Construction 2 05-23-2006 09:34 PM
