Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-09-2011, 01:12 PM   #1
Software to lay out stud walls?
Hello,
I am planning to build a small woodworking shop/shed this spring. I am drawing up plans now. Is there a freeware program that will help me lay this out with dimensions available?
Thanks,
deck
deck99 is offline   Reply With Quote
Old 01-09-2011, 01:22 PM   #2
Framing Contractor
Originally Posted by deck99 View Post
Hello,
Thanks,
deck
You can try "Sketchup" it's free.
http://sketchup.google.com/download/gsu.html
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-09-2011, 04:08 PM   #3
Thanks....I have been messing with it this afternoon..it's a pretty powerful tool but by the time I figure it out I'll have the shed framed .
deck
Old 01-09-2011, 05:09 PM   #4
Not sure about software. Are there anymore specific questions that we can help with on the layout or the construction?
redmanblackdog is offline   Reply With Quote
Old 01-09-2011, 05:15 PM   #5
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
deck
Sketchup would be way to powerful, the learning curve is VERY steep, also you need a gaming video card ( open GL 3) support for it to be accurate
Many Thanks
Ashley
© Copyright 2011 -
SFX Group is offline   Reply With Quote
Old 01-09-2011, 05:44 PM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pencil, paper & a ruler is the cheapest & easiest way. If you know the dimensions, and that all studs are either 16 or 24 o/c, it is not that hard to figure out from there. It was how it was done before computers became the norm, and is still done on the fly.
Old 01-09-2011, 06:15 PM   #7
Framing Contractor
deck
Your the one that asked for a program to figure out how to layout a wall. I gave you one and could've easily told you that you didn't need one to simply figure out how layout a wall. I'm glad you realize how easy it is that you could have the thing built already without a program.
Joe Carola
Old 01-10-2011, 10:13 AM   #8
I appreciate the help guys. I know how to lay out a wall. I just find it easier to work from a plan with measurements. Speeds things up for me. I just thought if there was a quicker way to do it but pencil and paper it is.
deck
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Help please...quick. Kilz dripping off walls jenllo Painting 7 01-24-2010 08:40 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 10:50 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
