Soft Close Hinge Won't Close Completely - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-30-2012, 03:34 PM   #1
Rewards Points: 77
Soft close hinge won't close completely
Staying at relative's beach house for the week. They have soft-close hinges/sliders everywhere in the kitchen. House is 8 months old.
Their garbage/recycling drawer no longer closes all the way on its own; it reaches the "soft-close" point and stops. It can be closed manually from there. Is there a simple fix/solution when this occurs?
dcj710 is offline   Reply With Quote
Old 08-30-2012, 08:21 PM   #2
the weight of the garbage can and its contents might be too much for the self closing mechanism. try removing all the cans and see if it closes all the way.
The Following User Says Thank You to DannyT For This Useful Post:
dcj710 (08-31-2012)
Old 08-31-2012, 11:57 AM   #3
Rewards Points: 77
I pulled them out to see "how it works" (didn't learn anything), but I hadn't tried closing without them in. Just tried it, no difference.
Somebody else's house...don't want to dig in too deep; probably have it torn apart at home. Slight adjustment, lubrication, etc.; is what I was hoping might be needed.
I think you might be on to something with the weight issue. Combine that with the frequency of use, and maybe it just wore out whatever makes it work. Googled that (what makes it work) online, and didn't find much help.
Old 09-01-2012, 11:23 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
it could be as simple as an out of line roller drawer guide that needs adjusting. if you can sight the mechanisms as they work do that to determine adjustments, etc... and then off to the beach!
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
dcj710 (09-01-2012)
Old 09-01-2012, 12:48 PM   #5
Rewards Points: 77
Sounds simple enough. I'll give that a try.
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Pull down attic stairs will not close completely gmalafarina Building & Construction 2 12-05-2010 11:09 AM
Flapper valve infrequently doesn't completely close Yoyizit Plumbing 4 08-30-2010 04:54 PM
Ice dispenser door does not completely close Larry Altherr Appliances 1 07-15-2010 12:39 PM
Window won't close completely bucksone General DIY Discussions 3 06-25-2009 06:57 AM
