Soffitt Slopes Toward Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-05-2007, 04:30 PM   #1
Soffitt slopes toward wall
After careful measuring, I somehow managed to put together a soffit that slopes the outside edge of the soffit to the wall. It's level from end to end but is one-half inch higher at the wall on one end and about one-fourth higher at the other end. I haven't taped it yet or put any mud on it so I'm wondering if there were any simpler solutions than taking it all apart.
I forgot to say that this whole section is just under 5 1/2 feet long.
Would building it up with mud to even it out be too crazy?
drhowarddrfine is offline   Reply With Quote
Old 08-09-2007, 11:58 AM   #2
Rewards Points: 5,336
It all depends on your taping skills. I would remove it and straighten it out. Snap guide lines on the wall so you know where to line up the wood.
Ron
Old 08-09-2007, 01:33 PM   #3
it would be a pain
Ron
It would be such a pain though....
1/2 " and 1/4" to me is really small
the key is can you feel the unlevel/unbalance visually, if not, I say just forget about it and get on... if you can feel it visually obviously.... then yes, the only option is take it down and rebuild the soffet.
KUIPORNG is offline   Reply With Quote
Old 08-10-2007, 12:51 PM   #4
Rewards Points: 1,910
Another option would be to put an additional layer of drywall up using shims as needed to level. Is the slope really noticeable?
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
