So I Installed A Telescopic Attic Ladder - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 07:42 PM   #1
GGConn88's Avatar
So I installed a Telescopic Attic Ladder
Installation went well but discovered today that my 1/2" furniture grade plywood door is a bit warped (not exactly flat). Any suggestions? Should I cut a new door or install some metal to keep it flat.
GGConn88 is offline   Reply With Quote
Old 05-10-2010, 08:06 PM   #2
Does the door rest on top of the jamb or is there a door stop on the face of the jamb.
If you have a door stop, just remove it and nail it back so that it meets the door all the way around!
Don't forget, that you need a rubber seal between the door and the jamb/stop!
Old 05-11-2010, 06:54 AM   #3
I assume you finished the door(all sides/edges) before installing it??? If no, make a new one. The difference in temp/humidity on attic and conditioned sides will continue to warp almost anything not well finished.
The Following User Says Thank You to Just Bill For This Useful Post:
GGConn88 (05-11-2010)
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
Attic fan in Attic access door kubotaart HVAC 10 09-17-2008 01:55 PM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 08:10 AM
Proper Attic Ventilation kmhill35 Roofing/Siding 2 04-01-2005 09:11 PM
