Snap On Brick Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 03:27 PM   #1
snap on brick molding
I think its a jeld wen door with plastic clad brick mold. how does it come off after the door is hung? some one put a door on a friends house and it has sagged and wont close. The latch is about 1/4 inch low.
jay drouin is offline   Reply With Quote
Old 07-18-2011, 07:49 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can try to adjust the door without pulling the brickmould
check the screws in the top hinge,one should be log enough to hit the framing and pull the top of the door over enough to line up the strikes
may be easier actually to pull the inside trim and shim the door properly
Tom Struble is offline   Reply With Quote
Vinyl windows and brick molding a7ecorsair Building & Construction 4 08-10-2010 09:54 PM
caulking for pvc brick molding cvbs Carpentry 4 07-23-2010 06:17 PM
pvc brick molding formyson1 Carpentry 3 06-29-2010 09:20 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
pvc brick molding ramies Building & Construction 6 07-13-2008 09:09 PM
