Smaller Floor Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 06:23 PM   #1
smaller floor joist
I have an older home, with a low basement, I want to increase the ceiling height as much as possible. the area is about 10'w x 12'l, it presently has 2 X 8 wood joist. how can I sister , or use metal angle or channel, so I can reduce the size of the existing joist to allow more head room?
ricksvette63 is offline   Reply With Quote
Old 03-13-2011, 06:38 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Assuming you are ripping out all the existing, reframe at 8" or 12" o.c. with a smaller dimension lumber.
You may still get some "spring" but it will not collapse.
tcleve4911 is offline   Reply With Quote
Old 03-13-2011, 06:58 PM   #3
Civil Engineer
Rewards Points: 4,520
If you have the money and time, you can always use steel I beams, the smallest commercially available are 3 inches deep. You will need an engineer to size the steel for you, and develop the connection details.
Daniel Holzman is online now   Reply With Quote
Old 03-13-2011, 07:56 PM   #4
Registered User
Rewards Points: 4,914
The most you would get with wood is 2" less, using 2x6 joists for that span. Hardly worth the bother. If an older house, many slabs are only 2-3" thick, demo the existing, dig down and pour a new lower slab. Figure the finshed depth to work with todays Codes for stair risers.
Gary
Old 03-13-2011, 10:26 PM   #5
Rewards Points: 83
Gary
Underpinning a house isn't that easy. Digging down can weaken the foundation. The earth outside will push the foundation inwards. An engineer would be a good idea before digging up the basement.
rubberhead is offline   Reply With Quote
Old 03-13-2011, 10:48 PM   #6
Registered User
Good point, hopefully the op would converse a little more before picking up a shovel.....
Gary
Old 03-13-2011, 10:56 PM   #7
Rewards Points: 83
Gary
Agreed. I like the mental picture of someone holding a shovel in the basement though.
Old 03-16-2011, 08:46 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
There was a thread in Contractor Talk about a HO who did just that.
He was digging out the basement to gain head room and the house collapsed around him while his wife was at work and the kids were in daycare.
There's a pic with the whole side of the house laying in the side yard and the babies crib hanging over the edge...........
Old 03-16-2011, 08:54 AM   #9
kwikfishron's Avatar
Rewards Points: 86
Where’s the link to that thread?
kwikfishron is online now   Reply With Quote
Old 03-16-2011, 11:46 AM   #10
For a 10x12 room, this is way too much work!!!
I just wouldn't do this.
pjordan4477 is offline   Reply With Quote
Old 03-17-2011, 11:14 PM   #11
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
http://www.wgal.com/slideshow/news/22027939/detail.html
Old 03-18-2011, 04:43 PM   #12
Tizzer's Avatar
Rewards Points: 452
Ditto.
I'm not certain the money spent for this project payback when its time to sell.
Even if the OP finds an approved engineered lumber/ steel joist size and someone qualified to replace them, there is still the issue of any hvac/electric/plumbing to be removed & replaced. $$$$$
Tizzer is offline   Reply With Quote
Old 03-19-2011, 01:51 AM   #13
How much are you willing to do/spend for a couple of inches? Don't bother.
Dusty1 is offline   Reply With Quote
Tags
smaller joist
Remove a big baseboard and add 2 smaller ones Metallo HVAC 6 01-29-2011 08:07 PM
replacement entry door is smaller france Carpentry 2 12-24-2010 01:59 PM
Water heater: larger and lower temp, or smaller and higher temp, energy use HVAC_NW Plumbing 1 10-11-2010 10:38 PM
Anybody work with numbered drills smaller than 0.0625"? Yoyizit General DIY Discussions 7 07-22-2010 02:15 PM
re: smaller cut ceramic tiles on ditra gramps416 Flooring 3 01-15-2009 11:32 AM
