Is A Small Notch In A Wind Brace Ok? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-27-2008, 07:47 PM   #1
Rewards Points: 150
Is a small notch in a wind brace ok?
I am running new electrical lines and just finished cutting out holes for my new boxes. I have wind braces in the walls and when removing one of the old boxes I found out that it is slightly notched in one area so they could get the box to fit. The brace is a 1x6 and the area that is notched kind of makes a L shape. It is about a 1 inch by 1 inch area that has been notched. Does this hurt the integrity of the brace? Thanks.
twilightcall is offline   Reply With Quote
Old 06-27-2008, 09:15 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Yes you will be ok A 1" notch in a 1x6 will be ok.
Most wind braces are 1x4 stock anyway.
Old 06-28-2008, 12:06 AM   #3
Registered User
Termite's Avatar
I totally agree with Buletbob. The wind braces work in tension and compression depending on the loads, but there's plenty of meat left in your 1x6 to do the job with no problem.
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 10:42 AM
small electric heater recommendation bdog1234 Electrical 9 02-24-2008 03:12 PM
X Brace, Cross Brace Removing ejensen1 Building & Construction 2 04-16-2007 06:08 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 11:38 AM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
