Small Gaps Between Tread & Skirt Board - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-25-2008, 03:54 PM   #1
Small Gaps between tread & skirt board
I installed 1" red oak staircase. It is enclosed on both sides. The skirt board bows out for some 3-4 steps in the run, following the countour of the wall. I did not scribe the steps, they were straight cut. I am snug where the nose meets the skirt, end up having 1/8" to 1/4" gap as you approach the riser. I intended on staining the stairs.
Any suggestions how I fill these gaps? Scribe in a shim? Putty? Quarter round over the gaps?
jcpullen is offline   Reply With Quote
Old 08-25-2008, 05:14 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
go under the stairs and shim the stringers in, to close the stair carriage.
Old 08-25-2008, 05:16 PM   #3
Registered User
Termite's Avatar
That's a tough one...
Are the skirtboards stained or painted? If it is stained, problem. If painted, you can mask and caulk, then remove the masking tape when the caulk is still wet. When dry, re-mask and paint the same color as the skirt.
If it is stained, I think I'd use a block plane to form an oak shim, and would glue it in. Wood putty would have to be used to fill in the narrow gaps. This will be really labor-intensive, and unfortunately the grain will be running the wrong way so it may still show up.
Heck, you might be able to find some colored caulk that wouldn't stand out too bad.
Old 08-25-2008, 05:16 PM   #4
Registered User
Termite's Avatar
Or do that! Not a bad idea there Bob!!!!!!!!!
Old 08-25-2008, 05:20 PM   #5
buletbob's Avatar
I hope I understand what he is trying to explain?
Old 08-25-2008, 06:50 PM   #6
More info
Bob / thekctermite, thank you for responding. I really appreciate it. The skirt is 12" poplar to be painted. Going to be jamming the shim a long way before it start to reach the affected areas. Is that still feasible?
What about taking a scrap of that exact tread, cutting a wedge & hitting it in with a rubber mallet, securing with poly glue? I could then sand flush with the tread? I've attached a picture of my issue.
Risers & skirt will be painted.
Thanks again!
-Jim
Old 08-25-2008, 11:57 PM   #7
Registered User
Termite's Avatar
Yeeouch!
Can you get to the underside of those stairs?
If so, pop off the riser board. Then use shims between the wall and the skirtboard to lessen the gap between it and the tread. It won't gain you much, but it might buy you a little.
If you're painting the skirt, I'd go with caulking on the tread to a masked line. If you caulk every tread the same it might not look too bad.
No way to talk you into removing and re-cutting those treads?
Old 08-26-2008, 04:43 AM   #8
Response #2
I do have access to underneath.
We're talking about 3 treads...yes I can buy 3 more and re-cut. How much space is generally acceptable between the skirt & the tread? Zero? 1/16?
Old 08-26-2008, 05:08 AM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Those look like poplar skirt boards, so I am assuming that those areas will be painted. So, you might be able to hide some of that with white caulking, and the skirt board paint. It won't look perfect, but the only other option is to remove those 3-4 treads and template new ones.
FWIW: We use a set of these: http://www.collinstool.com/base.php?...gauge_ends.htm
Best of Luck.
- Build Well -
Old 08-26-2008, 06:42 AM   #10
buletbob's Avatar
I see now. I was under the impression these where A set of boxed stairs. shimming is not going to help much because your cuts are off for those treads. I would do as Atlantic states remove and re-cut new ones.
Take a piece of card board or cut up an old shoe box. lay it on the tread and scribe it to the skirt board, keeping it tight along the riser, cut out the outline with some scissors. put the template you just made back into position and mark the rear of the template on the stairs. do the same for the other side with a new template. holding it tight to the skirt mark the stair tread. remove the tread and lay it on top of the new tread then install your template on top of the old tread keeping the back edge even with the mark you made on the tread. this is your scribe. do the same to the other side trying to not move the tread in the process. mark and cut .
They do make a stair jig for this type of installation. I'll see if I can locate it to post for future OP's BOB
here is a site where a home owner built on hope it helps
http://www.woodworkingbuzz.com/forum...hread.php?t=71
Old 08-26-2008, 06:57 AM   #11
Thank you
Thank you all very much for your feedback. Most appreciated.
Regards,
Jim
Old 08-26-2008, 08:54 AM   #12
One more related question
Gentleman, in lieu of tearing up the tread, kctermite suggested caulking & taping...
How bad/good would it look if I were to fill the gaps, sand them flush, tape a line approx. 1" from the skirt, and paint that area, along with the skirt and riser the same color. I would then stain and eurthane the unpainted majority of the tread.
Thoughts?
Old 08-26-2008, 12:19 PM   #13
buletbob's Avatar
If I was the contractor doing this install and came to the job to see what my men have done, there would be no second guessing about ripping those few treads out and replacing them. But this is your project and your home you will have to be the judge, we don't know what your talents as far as painting and staining are. It could turn out fine and then again it might not, if it does not then the whole stair is ruined. I'm sorry to say its your call. Whats the cost of the tread, Around 20 dollars ? and what have you invested into the whole project. is it worth taken a chance and have to look at this, every time you walk up the stairs?. let us know what you decide so we can help you further. good luck BOB
Old 08-26-2008, 12:43 PM   #14
Alright Bob, you got me. I wanted to hear you say I could skirt my way around it, but as I thought, I have to take it down.
I'll be sure to post back finished pics when I get to it... in October.
Thank you all again!
Jim
Old 08-26-2008, 01:06 PM   #15
buletbob's Avatar
Jim
Good choice!you will be proud of your self when your finished and every time you walk up and down the stairs. when these stairs are down correctly there absolutely beautiful. when your ready to cut your step tread post back we will help you through it. BOB
gaps between solid treads & skirt boards shotdown Flooring 9 08-02-2009 10:43 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 03:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 07:43 PM
Ridge Board vs Beam carrying load fauer Building & Construction 3 01-19-2008 09:39 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
