Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-10-2009, 12:15 PM   #1
small area of rotten wood on deck
On one corner of the surface of my deck, where there is a small column standing on it, the wood is soft. In total, the soft area is something like 3in x 3 in. I am not planning to redo the deck yet, and would like to fix the little area for now.
What method and what product should I use for this?
Thanks in advance.
hohadcr is offline   Reply With Quote
Old 09-10-2009, 05:11 PM   #2
A picture of this and one of the deck would be helpful if possible, but based on what you've posted i would say the only good way to replace this would be to replace that one piece of decking. But if your planning on replacing the deck within a year or so i would wait until you rebuild the deck to fix this problem since the decking material isnt really a structural part of it. I could be way off on this and if i am dont worry someone will correct me, but i think a couple pictures would get you a more accurate response
912jake is offline   Reply With Quote
More On This Topic
Hello I'm Paul Popplewell with Central Equipment Company I've been employed with them for 18 years. I'm here today to represent expert village. Now we want to check our deck belt for wear, to do that we can roll the deck belt around and check it. We want... Read More »
We all have moments where we wish we had done something differently, and sometimes those moments have consequences. However, some of the best blessings or moments of achievement come after failure or disappointment. A setback can be a valuable learning... Read More »
Hello, my name is Mark Blocker and I'm with Expert Village and in this segment we are going to cover how to properly replace a fuse and seeming up the system. Once you've got your fuse, your defective fuse and it comes time to install it, you need to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Once the root canal is done, we want to rebuild the crown portion. For the most part, after the root canal, the crown portion of the tooth structure is basically damaged or is gone due to some form of cavity or trimmed away to access the chamber of the... Read More »
Composite vs wood deck screws cranedk Building & Construction 2 08-04-2009 01:07 AM
I'm building a small deck and ole 66 Carpentry 3 07-27-2009 10:21 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
