Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-22-2011, 09:33 PM   #1
Small Amount of Black Mold on Studs in Bathroom
Ok so I tore apart my bathroom and behind where the tub/shower was, there was a little black mold, on the drywall and on the 2x4s. I was getting rid of the drywall anyways so thats gone. On the other side of the 2x4s (so same wall but just other side) is a sitting area and that was just refinished, so I dont want to have to take out the 2x4s and put in new ones or else it will wreck the wall on the other side. Could a guy use bleach or something for the little bit of black mold thats on them then continue with my bathroom renovation? Or is there something they make that i could spray on the black mold to get rid of it? I really dont want to have to replace them and have to redo the sitting area again.
Any help would be appreciated.
TheWildcat is offline   Reply With Quote
Old 10-23-2011, 08:10 AM   #2
A 10:1 water bleach solution will get rid on the mold. Allow it to completely dry, then install 6 mil plastic to that wall after insulating. Insualtion is good for either an outside wall in inside wall. Inside, it reduces noise. Then backer board and tile.
Old 10-24-2011, 03:55 PM   #3
gravity always wins
As mentioned above, a 10-1 mix of water and bleach. Clean the mold off. When dry, spray or brush a sealer on the studs. The sealer will lock down any stray mold components that the bleach coudn't reach.
Maintenance 6 is online now   Reply With Quote
Black mold: Yikes!!! DIYChick45 General Discussion 6 07-27-2011 07:08 AM
Mold in bathroom exterior wall Chemist1961 Building & Construction 11 07-05-2011 12:22 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
small bad spot on bathroom floor Steph Flooring 4 03-05-2009 10:43 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
