Sliding Glass Door: Inserts Or Replace? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 01:46 PM   #1
Rewards Points: 168
Sliding Glass Door: Inserts or Replace?
HI: I have the old aluminum frame 1 fixed the other sliding, slinging glass doors.
They are not plumb and leak air badly. They are in a rental apartment and go out to a balcony.
Are their retrofit replacement windows that can go inside the existing aluminum frame so I don't have to pull out the existing frame?
THanks,
Tom
roztom is offline   Reply With Quote
Old 07-20-2008, 02:44 PM   #2
Be green & save green
yes retrofit windows are used exactly for this situation.
mgsproperties is offline   Reply With Quote
Old 07-20-2008, 02:48 PM   #3
Rewards Points: 168
Just to clarify your post, I am NOT techy.
Are you reeferring to a retrofit kit that goes inside the existing aluminum frame?
Can you give me the names of some manufacturers or sources?
Thanks,
Tom
Old 07-20-2008, 02:57 PM   #4
I would go with vinyl retrofit windows
try milgard, superior
Old 07-20-2008, 03:05 PM   #5
Rewards Points: 168
DO this go inside the existing aluminum frame, like a frame within a frame or is it a tear out and replace?
This is for a rental unit. Need to avoid overkill & Cost..
Thanks for your help,
Tom
Old 07-20-2008, 03:44 PM   #6
Tom
the actuall aluminum frame that you see gets removed but the nail on part that is nailed into the studs and has stucco/siding over it does not .
the window wil lcost you anywhere from 150-350 depending on size and the labor is fairly easy. you will not damage the stucco or drywall. you might need to also purchase some molding as well depending on what u currently have installed.
Old 07-20-2008, 03:53 PM   #7
Rewards Points: 168
THanks for the info.
MY current ALum frame is not plumb. If I use a retrofit can this be compensated for with shims?
Tx,
Tom
Flashing sliding glass door ncgrogan Project Showcase 0 04-27-2008 09:14 AM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 04:34 PM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 12:43 AM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 09:06 PM
