-   -   Sliding Glass Door: Inserts or Replace? (http://www.diychatroom.com/f14/sliding-glass-door-inserts-replace-23970/)
roztom 07-20-2008 02:46 PM
HI: I have the old aluminum frame 1 fixed the other sliding, slinging glass doors.
They are not plumb and leak air badly. They are in a rental apartment and go out to a balcony.
Are their retrofit replacement windows that can go inside the existing aluminum frame so I don't have to pull out the existing frame?
THanks,
Tom
mgsproperties 07-20-2008 03:44 PM
yes retrofit windows are used exactly for this situation.
roztom 07-20-2008 03:48 PM
Just to clarify your post, I am NOT techy. :censored:
Are you reeferring to a retrofit kit that goes inside the existing aluminum frame?
Can you give me the names of some manufacturers or sources?
Thanks,
Tom
mgsproperties 07-20-2008 03:57 PM
I would go with vinyl retrofit windows
try milgard, superior
roztom 07-20-2008 04:05 PM
DO this go inside the existing aluminum frame, like a frame within a frame or is it a tear out and replace?
This is for a rental unit. Need to avoid overkill & Cost..
Thanks for your help,
Tom
mgsproperties 07-20-2008 04:44 PM
Tom
the actuall aluminum frame that you see gets removed but the nail on part that is nailed into the studs and has stucco/siding over it does not .
the window wil lcost you anywhere from 150-350 depending on size and the labor is fairly easy. you will not damage the stucco or drywall. you might need to also purchase some molding as well depending on what u currently have installed.
roztom 07-20-2008 04:53 PM
THanks for the info.
MY current ALum frame is not plumb. If I use a retrofit can this be compensated for with shims?
Tx,
Tom
