Sliding Closet Door Hardware - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 12:51 PM   #1
sliding closet door hardware
I'm looking for and am having a hard time finding a hardware kit that would enable two pieces of 1/4" plywood to act as sliding closet doors. The kit would contain a knock-down metal frame to surround the 1/4" plywood as well as the remaining necessary sliding door hardware. Can anyone help me locate a source?
ovenledg is offline   Reply With Quote
Old 05-20-2013, 02:40 PM   #2
Rewards Points: 2,210
Maybe you could buy the mirrored doors and pull out the mirror and put in your panels.
mae-ling is offline   Reply With Quote
Old 05-20-2013, 02:44 PM   #3
Rewards Points: 13,300
Google bi pass doors.
Old 05-20-2013, 06:28 PM   #4
Joe - have you seen a kit with a frame for 1/4" panels? I haven't.
Old 05-20-2013, 06:56 PM   #5
Nope, why reinvent the wheel. Those bi pass doors are cheap to buy as a prehung assembly. Why would you want to make one?
Old 05-20-2013, 08:28 PM   #6
Too Short? Cut it Again!
You could probably use hardware and such usually intended for glass but a 1/4" closet door of wood is too thin to be of much use. Maybe something like tempered masonite will work but I fear it is going to warp like crazy. Ordinarily you would at least cross brace the back of such material.
Would a designer barn door hardware approach, with the hardware on the outside, and hanging panels on the exterior of the opening solve your problem? Something like this but perhaps not glass and more understated hardware?
Old 05-21-2013, 09:18 AM   #7
Rewards Points: 150
Maybe a custom thing? I could see making some artistic stuff w a router and then using that as a panel for doors.
Altho, plywood tends to get a bit warpy. Especially 1/4". I don't know if that's ideal slider material. But, maybe a good frame would keep it flat.
SquishyBall is offline   Reply With Quote
How to make beadboard end near sliding closet door zacharinas Remodeling 5 08-03-2013 08:15 PM
Sliding Glass Closet Doors newhome2 Interior Decorating 6 11-02-2010 01:42 PM
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 11:09 AM
Sliding Closet Door Track PTivvy Flooring 2 06-19-2009 09:16 AM
Painting a sliding closet door javan Painting 1 06-25-2008 11:47 AM
