Slgrumpy - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 03:18 PM   #1
Unhappy
slgrumpy
Hi,
I'm in the process of building a Hip roof for a 10 X12 Storage Shed.
I have my rafters up and ridge erected and the hips are in. I finished framing one side of the Jacks, They came out fine! I have now started on the other side. My question is I'm not arriving at the right slope angle at the hip. I'm in the process of installing Jack rafters. My pitch is 4/12 w/ 18 deg. slope. My cuts are not working out now.
I think I am cutting the wrong way, on my jack rafter? can someone that has built a hip roof help me out of my delima?
slgrumpy
Last edited by slgumpy; 07-31-2008 at 03:23 PM. Reason: add to the subject: Having trouble with Hip/slope angles!
slgumpy is offline   Reply With Quote
Old 07-31-2008, 06:27 PM   #2
I moved your question to the Carpentry sub-forum for you to have a chance at better advice.
Maybe the building and construction would also work, but les see if you get your responses here.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-31-2008, 11:22 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
could you post a pitcher of the roof and jack rafters. what does not match up. your cheek cuts? the plum cuts on the jacks should be 18.43 degrees ( or 18-1/2 ) when the jack rafter is in place does the fascia cut lay plumb or does it tilt up. What does not line up?? did you drop your hip at the wall?. Post a picture. BOB
