Slate Or Cement Sealer Used On Timber Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 11:21 PM   #1
Slate or cement sealer used on timber deck
Is there a reason I can't use use slate/cement sealer on a timber deck?
I know it may sound strange but I like the fact that when slate is due for re sealing, there is really next to no prep work other than cleaning prior....and the new sealer is rolled over the old. Even if it took 3 or 4 times the first time....will it work??
softus is offline   Reply With Quote
Old 11-17-2012, 08:13 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
slate is completely different from wood in its make up and porosity, etc... wood will not hold slate sealer like the slate will. get sealer made for wood...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
PaliBob (11-19-2012)
Strip water based S.W. sealer off my deck? (Pics) John in NC Painting 6 09-05-2012 01:56 PM
Cement Crack Sealer or Cement Resurfacer to fix a 1/8" crack toofan9 Flooring 1 08-03-2012 08:37 PM
Deck Sealer??? jte1130 Painting 5 12-13-2011 01:45 PM
deck stain or just sealer robotgib Painting 3 07-16-2009 07:11 PM
Laminate timber flooring over exsisting slate scott10 Flooring 6 06-20-2008 05:04 PM
