Slab On Grade Foundation For A Shed? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 04:59 PM   #16
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
anchor bolts will actually hold the structure to the concrete.. concrete nails arent rated for what your intending to do.
after the concrete has been placed and cured, if you forgot the anchor bolts you can still bolt down the plates using a hammer drill and 1/2 bit.. then anchor it wedge anchors. as you tighten the nut the opposite end will spread creating more and more friction. i use them all the time in renovation situations and are accepted by code. concrete nails are not
woodworkbykirk is offline   Reply With Quote
Old 11-18-2011, 05:20 PM   #17
Rewards Points: 150
We can use concrete nails here.
CJIII is offline   Reply With Quote
Old 11-18-2011, 05:29 PM   #18
are you sure about that,, the hole point of anchor bolts is to hold structure down plates in extremely strong winds..
i would double check your info
Old 11-18-2011, 05:32 PM   #19
Rewards Points: 150
We really dont have strong winds, but I will double check.
Old 11-18-2011, 06:18 PM   #20
Rewards Points: 1,216
Nobody has strong winds, floods, hurricanes, tornado's, tsunami's, snow storms, floods, hail, sand storms, earthquakes, ETC ETC.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Willie T (12-02-2011)
Old 11-18-2011, 07:46 PM   #21
Civil Engineer
Rewards Points: 4,572
Of course you can use concrete nails, since you apparently don't need a permit. The point is not that you can use nails, the question is whether they will accomplish the goal of holding the foundation to the slab. They won't, anchor bolts will. But you can use toothpicks if you want, since you don't need a permit, and there are likely no design standards.
As for no wind in Montgomery, I disagree. I spent six months investigating damage after hurricanes Katrina and Rita, including a few tornado related incidents in northern Mississippi. You live in an area of the country that has tornado potential. Will the anchor bolts save your shed if a tornado hits? If it is a low grade tornado, very likely, especially if you use hurricane clips on the roof. But since it is a shed, you may not be too concerned about wind damage, and it may be economically justified to save the money on hurricane clips and anchor bolts, and accept wind damage in the event of a strong wind event. Your call.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 11-18-2011, 10:17 PM   #22
yah, and this guys doesnt seem worried about having to drag his shed back to his property from 2 streets over when it starts to blow either.
if your not going to do something to code it better be because your going above and beyond code.. i dont kow how many times inspectors have shook their head at me because of being "captain overkill" they liked what they saw but were happy they werent the one paying the bill to get it done
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 11-19-2011, 07:33 AM   #23
Check this out- I don't need hold down bolts they are not required. Meanwhile there's a windstorm and the shed lifts off the slab and blows through a couple yards and thousand's dollars damage to the neighbors property, oh well I say it's only a shed I lost.
Check this out we're driving in the car everyone has seat belts on except one person he says I don't need it. Meanwhile we get in an accident and the guy that wouldn't put the belt on flys around in the car and kills two other people and he is not seriously injured.
The Point, who cares about what happens to other peoples property or lives.
woodworkbykirk (11-19-2011)
Old 11-30-2011, 11:21 PM   #24
Missouri Bound's Avatar
Just dig a trench around the perimier of the slab to act as a small footing. It's sometimes referred to as a "turn down slab"
You can pour it all at once.
Old 12-01-2011, 10:04 AM   #25
Rewards Points: 150
Thanks guys for the advise.
Old 12-02-2011, 08:41 AM   #26
Rewards Points: 13,300
What's going to happen if you do not take the extra time and money to pore this much higher then the surrounding grade is the splash back evertime it rains will rot out the siding and water can get under the bottom plates and into the building.
The slab should not be any bigger then the foot print of the shed. If it is then water will work it's way in.
I'd also have an exterminater come out and do a fan spray before the slab goes in to stop termites from coming in.
It would be best to also lay 6 mil. plastic before the pore to stop moisture from coming in throught the slab.
I've torn down many sheds and had to replace more then a few bottom plates in slab floor homes.
Everyone thinks because they have a slab there less chance of termites. Not true. The building is closer to the ground and one crack and there in.
Old 12-02-2011, 10:06 AM   #27
Rewards Points: 150
I am going to build up the yard with aleast two or three truckloads of sand. Spraying for termites is a good idea.
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 05:59 AM
Foundation insultation above grade Jacques1878 Insulation 0 03-15-2011 06:50 PM
Long crack in slab foundation dbower Building & Construction 1 01-02-2011 08:47 PM
shed foundation jkirby65 Building & Construction 1 10-30-2009 05:42 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
