Slab On Grade Foundation For A Shed? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 03:30 PM   #1
CJ21's Avatar
Slab on grade foundation for a shed?
Have anyone heard of a slab on grade foundation for a shed. I think it would where I live because out frost line is only a few inches deep.
CJ21 is offline   Reply With Quote
Old 11-17-2011, 04:15 PM   #2
Civil Engineer
Rewards Points: 4,854
I think there were a few words missing from your post, but I gather you are asking if a slab on grade is suitable for supporting a shed. If local building regulations permit, it certainly can be used. You must be in a warm climate, since you state that frost is only a few inches deep, so that eliminates issues with frost heave. Many areas of the country have expansive clay soils, which can be problematic with slabs due to non-uniform soil movement, but since you do not state where you live, it is impossible to know whether that could be an issue where you are.
Old 11-17-2011, 04:19 PM   #3
Rewards Points: 150
I live in Alabama. Building department here dont require a foundation for a outbuilding under 400 sq ft.
CJIII is offline   Reply With Quote
Old 11-17-2011, 04:23 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
yup, it gets done the only thing is if you do it you'll want a curb so to keep water and such out when you frame. it basically keeps the concrete to wood joint up off of the ground
woodworkbykirk is offline   Reply With Quote
Old 11-17-2011, 04:27 PM   #5
Rewards Points: 150
I read somewhere you need to slope the sides?
Old 11-17-2011, 09:32 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Yeah you can do those all day long in Montgomery, Al.
Some folks here even do plans for that kind of thing if you need to get permits or just to build.
Hint, hint, nudge, nudge.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
woodworkbykirk (11-18-2011)
Old 11-17-2011, 10:08 PM   #7
Rewards Points: 150
I am going to get a permit.
Old 11-17-2011, 10:27 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 476
CJ, I see you like fishing, you wouldn't happen to be a member of the BOC would you?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-17-2011, 10:31 PM   #9
Rewards Points: 150
Yes I am a BOC member as well.
Old 11-18-2011, 06:24 AM   #10
Rewards Points: 1,216
No problem I have done it several times and I am from PA, don't forget to put anchor bolts in the concrete when its wet and use pressure treated plates.
COLDIRON is offline   Reply With Quote
Old 11-18-2011, 08:01 AM   #11
concretemasonry's Avatar
Rewards Points: 2,626
CJ -
I think the sloping could be used on one the oversized area around the shed to make sure there is positive drainage away and not into the shed.
Dick - The world's greatest fisherman and second best liar.
concretemasonry is offline   Reply With Quote
Old 11-18-2011, 08:05 AM   #12
Rewards Points: 150
I was thinking just to use concete nails.
Old 11-18-2011, 11:05 AM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 476
CJ, my call name on the BOC is fish, good to see you buddy.
Jim
Old 11-18-2011, 11:28 AM   #14
Rewards Points: 118
CJ, I think that you're in good shape, up to your last post. Use anchors, as Coldiron suggested, not nails.
The Following User Says Thank You to DexterII For This Useful Post:
Old 11-18-2011, 12:00 PM   #15
Rewards Points: 150
Yes I love to catfish.
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
Foundation insultation above grade Jacques1878 Insulation 0 03-15-2011 05:50 PM
Long crack in slab foundation dbower Building & Construction 1 01-02-2011 07:47 PM
shed foundation jkirby65 Building & Construction 1 10-30-2009 04:42 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
